Nismojunky Posted October 28, 2008 Share Posted October 28, 2008 i need to know a good High Flow Catalytic Converter thats on the cheap side, and a muffler that sounds alright but inst going to taake me to the cleaners? any ideas? Link to comment Share on other sites More sharing options...
Simon Posted October 28, 2008 Share Posted October 28, 2008 There's tons. However, it depends on how much you want to spend. There's aluminized stuff that's cheap, and you could just throw a glasspack (Cherry Bomb) on for a muffler. They can be had for around $20 at CT. For the high flow cat, just call around for the cheapest one you can find. Probably be around $80-100 If you want to go stainless, it'll cost you. Link to comment Share on other sites More sharing options...
Nismojunky Posted October 28, 2008 Author Share Posted October 28, 2008 muffler i was expecting to spend around 150-200 Link to comment Share on other sites More sharing options...
Simon Posted October 28, 2008 Share Posted October 28, 2008 If you're not doing the whole exhaust (all the pipes and everything) there's no need to spend big money on the cat and muffler. If you want to do the whole exhaust, expect to spend 8-900 on a full high flow stainless system. Link to comment Share on other sites More sharing options...
Precise1 Posted October 28, 2008 Share Posted October 28, 2008 Check rummitracing.com. I saw a dynomat universal high flow cat for $50. Google will be your friend. I found all sorts very easy (flanged, slip fit, welded, etc), I just can't remember the site names now. B Link to comment Share on other sites More sharing options...
MY1PATH Posted October 28, 2008 Share Posted October 28, 2008 IMO Best bang for buck; 2.25 Magnaflow bolt on cat, found mine on ebay for 70-80 bucks 2" magnaflow stainles muffler(not polished), on summit racing for 80 bucks had a $5 bolt on flange welded directly to the muffler so it bolts to the cat and a 2" tailppe made to come out just before the rear fenderwell $60 @ the exhaust shop. they said they'd make me a new 2-2.25" mid pipe (for o2 sensor) that bolts on for another 50 but I held off for now. So full exhaust from my thorley y pipe back cost me(including the mid-pipe I didn't get made) 80+80+5+60+50= $275 not to bad fo full exhaust. I might add that I do not think you need to replace all your pipes when going to the high flow set-up. the less restriction @ the cat & muffler will allow a much higher velocity of exhaust gass to go thru the stock pipes. Increasing diameter does reduce restiction to an extent but also increases volume which reduces velocity. the trade off is where it locates your torque band. Link to comment Share on other sites More sharing options...
nige Posted October 28, 2008 Share Posted October 28, 2008 i got a magnaflow cat for $75 and a flowmaster 50 series for $140. I got the cat from partsource and the shop that installed it bought the muffler for me. Link to comment Share on other sites More sharing options...
