alarm plus randoms
edicer2
ok im sure you guess have heard of this problem before but i just cant figure it out. i am the second owner of my 93 pathfinder se. The previous owners didnt take care of their stuff to well but i got it for only 500 bucks. Anyways i have 3 questions
1. my security light blinks constantly really fast whether i have it on the on position impact or off. Either way the light flashes really fast and never changes. It also is always on even when the car is running. what could cause this? I have check the normal stuff like the door jam switches and they should all be good because when i open the door all the lights come on with each of the doors. What else is there to check? Also would this be related to my doors randomly locking when i pull up on the handle or when i close the door it will sometimes lock by its self.
2. I also am curious if my pathfinder came with keyless entry and the previous ppl just lost the remotes. Is there a way to tell? I have the security alarm, power locks and windows. Pretty sure it had everything besides headed leather seats.
3. Also i went behind my freinds shop which has a few chopped up logs that i was tring to drive over since i just removed my rear anti sway bar. I was able to shift into 4h but when i pulled the shifter down it felt like it was going into N and didnt feel like it was in 4L at all. It felt the exact same at 4H after doing so. Did it not go into 4L? Also it didnt go into N at all because no mather what the position i had the shifter at it would always be engaged. You should be able to notice the difference between 4h and 4L right?
Edited by edicer2
Typically, if you have the alarm switch, you should have keyless entry in the later model WD21's. Quite possible the PO's lost the remote.
Double check the connections at the alarm "brain" under the drivers seat. Could be a loose connection causing your flashing, or just a dead alarm.
4H and 4L should be different yes. You should have to push down on your shifter to get into N or 4L If not, there's something wrong with the linkage I'd suspect.
Mine gives me a little grind going into 4L, when stopped and have the tranny in Neutral, but that just lets me know it's working. :aok:
1) The rapid flashing indicates some sort of error. Check the connectors under the drivers seat. You may also try disconnecting the negative battery terminal to see if it clears the error. I also believe the insert on the alarm that would be with the owners manual talks about the errors. (if you still have it)
2) Your pathy did come with keyless entry. Part number is 999U7-6D001
