inwood73 Posted August 6, 2008 Share Posted August 6, 2008 (edited) Ok well today i put in my new condesor for my a/c, now i have found another leak, it seems somehow the small line going into the evap.at the firewall by the rubber seal thing has a leak, now does anyone know if this little line is attached to the expansion valve, or is it a small piece i can buy, after i figure out how to get the darn evaperator out??? i have searched but didn't come up with what i was looking for, i have a 1995 pathfinder, can someone exlplain to me how do i get the evaperator box out?? i'm pulling my hair on this, any help on any of the two problems would be great. Thanks. Mike. Edited August 6, 2008 by inwood73 Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 7, 2008 Share Posted August 7, 2008 I'm pretty sure its brazed onto the evap...its a bitch and a half to get to...you pretty much need to pull the blower motor dash and then disconnect all the levers and all of that jazz then pull it out...its a royal PITA... Link to comment Share on other sites More sharing options...
Alkorahil Posted August 7, 2008 Share Posted August 7, 2008 Here is the set up: Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 7, 2008 Share Posted August 7, 2008 Just a note up and to the left corner is FWD Link to comment Share on other sites More sharing options...
inwood73 Posted August 7, 2008 Author Share Posted August 7, 2008 so i have to remove the dash, then blower, and fish around for whatever else is atached to it, man this is going to be fun, i already put in a new condensor, so i'm not going to stop now, just i new exactly what steps to get the damn thing out, it's going to be a day or two job. looks like i might have to wait until i can afford the compressor, don't want to leave lines disconected for long, moisture and such. man i get myself into the most PITA situations. i'll never learn. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted August 7, 2008 Share Posted August 7, 2008 Here is the description from alldata.... 1995 Nissan-Datsun Truck Pathfinder 4WD V6-2960cc 3.0L SOHC MFI (VG30E) Vehicle Level Heating and Air Conditioning Evaporator Core Service and Repair Service and Repair Notes Fig. 8 Exploded View Of A/C & Heater System Disconnect battery ground cable and discharge A/C system. Discharge only into the proper recycling equipment. Do not release refrigerant into the air. Remove passenger side instrument lower cover and glove compartment. Disconnect wiring harness connectors to evaporator. Separate cooling unit case halves and remove evaporator, Fig. 8 . Reverse procedure to install. Link to comment Share on other sites More sharing options...
unccpathfinder Posted August 7, 2008 Share Posted August 7, 2008 Here is the description from alldata.... 1995 Nissan-Datsun Truck Pathfinder 4WD V6-2960cc 3.0L SOHC MFI (VG30E) Vehicle Level Heating and Air Conditioning Evaporator Core Service and Repair Service and Repair Notes Fig. 8 Exploded View Of A/C & Heater System Disconnect battery ground cable and discharge A/C system. Discharge only into the proper recycling equipment. Do not release refrigerant into the air. Remove passenger side instrument lower cover and glove compartment. Disconnect wiring harness connectors to evaporator. Separate cooling unit case halves and remove evaporator, Fig. 8 . Reverse procedure to install. I had my dash out and it was still a huge PITA which is y i left my 87 evap in instead of swapping it to the 94 that I had on hand at that time...its not going to be fun but I couldnt really figure out a good way to disconnect all of the cables without just pulling the dash out 1st...but pulling the dash easy and takes like 30 mins or so... Link to comment Share on other sites More sharing options...
inwood73 Posted August 9, 2008 Author Share Posted August 9, 2008 ok great guys, i'm going to the scrap yard tommorow and going to use a scrapper as a guiniea pig. lol. Link to comment Share on other sites More sharing options...
inwood73 Posted August 10, 2008 Author Share Posted August 10, 2008 well here is a update, it's all done, and was really easy, i went to parts day today at standart auto. found a 95 pathfinder with 10k on it, i almost crapped. anyhow removed the entire a/c system that was still charged, that wasn't fun, took everything exept the condesor which i had bought last week, took me about 2 hours to totaly remove, got home, opended glove box, removed the glove box and the little steel pannel behind it, unhooked the wires didn't even remove the blower, the evap falls right out pretty much, anyhow installed all the parts with 10,000 klm on them and worked like down town, i am very happy, i also took the intake with all the sensors and removed the rockers and lifter assembly as well. no all i have to do is put that in my engine. made sure all the lifters stayed in there keepers. got a really nice set of blue NGK wires that appear to be new as well. made off pretty well for 50 bucks. almost killed myself carying all the stuff out in a bed sheet lol. no i just have to fix a fuel line i found today thats been stinkin up my garage. i guess thats tommorow project. just thought i would fill ya's in on my progress. i couldn't believe how easy it was, thought i was going to have to fight with it the whole way. begining to really like working on this truck. Link to comment Share on other sites More sharing options...
adamzan Posted August 14, 2008 Share Posted August 14, 2008 a 95 with 10k on it? Must of been an accident victim Link to comment Share on other sites More sharing options...
inwood73 Posted August 16, 2008 Author Share Posted August 16, 2008 i put in the passenger side cam followers and rockers, no more tick whatsoever, now i just have to take the drivers side off, damn plenum, there is more wires on that damn thing than a plate of spagetti. i wish i could have gotten the whole damn thing, o'well. a/c is still working ice cold, man i love it. lol. thanks for your help guys. Link to comment Share on other sites More sharing options...
