help... i think i indexed my stock t bars wrong.
Coucoui6
okay i just installed 1/2" spacer btw the upper control arm and the ball joint? so i reindex it? but i also added a few clicks clockwise for the passenger side and counter clockwise for the driver side. did i do it right? i just seems like i have the t bar cranked pretty high to get the lift? i cranked the t bars before i added the spacer but it just seems like should have more adjustments since the spacers are in.
thanks,
coucoui 6
installing a spacer under your UCA ball joint will help correct your lifted camber as well as allow a little more downtravel. I don't think It will change your ride height or T-bar Ajustment (unless your trying to get more lift out of it w/o hitting the uca bumpstop)
where did you get your UCA ball joint spacer btw?
i got it from 4x4 parts.com. it was cheap...
