rod_b Posted January 29, 2008 Share Posted January 29, 2008 I have a 96 R50. Does anyone know where I can tap the speed sensor wire for GPS? I did a search here and on Google and only found info for a 2001. The only info I could get was that it was a green\yellow wire connected to the speedo. Anybody know for sure? Thanks Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 29, 2008 Share Posted January 29, 2008 Not sure where the speed sensor wire is under the dash, but if you're willing to run a wire under the truck, you can definitely get a signal at the speed sensor itself, which is attached to the right side of the transfer case. Link to comment Share on other sites More sharing options...
tmorgan4 Posted January 29, 2008 Share Posted January 29, 2008 There is a speed sensor wire that goes into the ECU if you have an automatic, but I don't recall seeing one in my 5-speed harness. I know the ECUs operate fine (with a manual transmission) without the speed sensor, so I'm not sure whether they have one or not. What are you wanting to put a speed signal IN to your GPS for? Shouldn't the GPS be telling YOU the speed? Link to comment Share on other sites More sharing options...
02silverpathy Posted January 29, 2008 Share Posted January 29, 2008 lol, it probably wants to know for sure that the truck is moving...there should be a speed sensor wire behind the intrument cluster, and for some reason I remember pink but anyhow...def behind the gauges! Link to comment Share on other sites More sharing options...
tmorgan4 Posted January 29, 2008 Share Posted January 29, 2008 Hopefully it isn't one of the features where it blanks out everything so you can't mess with the navigation while you're going more than a few miles an hour. In that case, I'd bypass it! Link to comment Share on other sites More sharing options...
rod_b Posted January 29, 2008 Author Share Posted January 29, 2008 Thanks for the info guys. I guess I'll dig around more. My GPS is an in-dash Kenwood and it uses the speed sensor wire to know for sure that the vehicle is moving. It still provides map information without the wire connected but will not do routing. Strange, I know. Oh well. Thanks again. Link to comment Share on other sites More sharing options...
93xe Posted January 29, 2008 Share Posted January 29, 2008 on my '97 automatic, speed sense was yellow/white wire at the cruise control module in the driver's side kickpanel Link to comment Share on other sites More sharing options...
CALPATHY Posted January 30, 2008 Share Posted January 30, 2008 (edited) Or you can go the expensive route: Dashdyno Edited January 30, 2008 by CALPATHY Link to comment Share on other sites More sharing options...
