sfBAYarea Posted June 15, 2007 Share Posted June 15, 2007 was wondering if d21 3"super lift uca's will fit a wd21 uca. thanks for the info. Link to comment Share on other sites More sharing options...
jj big shoe Posted June 15, 2007 Share Posted June 15, 2007 Yup, sure do. That's what is on mine. Link to comment Share on other sites More sharing options...
sfBAYarea Posted June 15, 2007 Author Share Posted June 15, 2007 big shoe, what size front shocks are you running? 3" over? the gold tubler is so sweet looking on those uca's thanks Link to comment Share on other sites More sharing options...
aries247 Posted June 15, 2007 Share Posted June 15, 2007 you can use stock length front shocks. Link to comment Share on other sites More sharing options...
Simon Posted June 15, 2007 Share Posted June 15, 2007 Yep...search around. There's almost nothing you can do to the IFS (independant front suspension) to increase travel. New UCA's do not increase travel. The only thing that will is removing the bumpstops, though, it's not recommended as you'll go through CV's any time you wheel. Stock length shocks are fine, as with a lift, they'll just sit at a further extended position within the stock range of travel. Link to comment Share on other sites More sharing options...
sfBAYarea Posted June 17, 2007 Author Share Posted June 17, 2007 so 3" uca's and stock shocks? or one over for middle of the road? thanks Link to comment Share on other sites More sharing options...
Slick Posted June 17, 2007 Share Posted June 17, 2007 SF/bay area huh? I am from "the other side of the hill" (now live in the central valley).... anyhoo, yes, stock shocks are fine. there is very little flex in the IFS as simon explained. Link to comment Share on other sites More sharing options...
GrimGreg Posted June 17, 2007 Share Posted June 17, 2007 Here's what they mean; when you "lift" the front suspension all you are doing is raising the position of the suspension in it's travel area. Nothng changes to it's range of movement from stock, just where is sits in that range normally. Same movement range/lenght, same size shock for stock or lifted. Link to comment Share on other sites More sharing options...
sfBAYarea Posted June 17, 2007 Author Share Posted June 17, 2007 that makes sence. the arm is not moving any further because of the bump stops and the lift is just making the truck sit highter with the same suspension range.. but if the shock is bit longer wont the shocks internal piston be more in the middle of the shocks range instead of being on the top on the shock almost on the bump stop? i just want the shock to have equal dampining both sides of the internal valve..? thanks again.. Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 17, 2007 Share Posted June 17, 2007 It won't matter. They will still work exactly the same. I've tried longer fronts, there's no difference. Link to comment Share on other sites More sharing options...
GrimGreg Posted June 17, 2007 Share Posted June 17, 2007 If anything you might damage a longer shock in the front by over compressing it. I blew a stock one before I replaced a missing lower bump on mine. Link to comment Share on other sites More sharing options...
sfBAYarea Posted June 18, 2007 Author Share Posted June 18, 2007 thanks for the info.. i'm going to order some stock length front shocks with my d21 superfilt 3" uca's hella juiced. Link to comment Share on other sites More sharing options...
El Pathfindero Posted June 20, 2007 Share Posted June 20, 2007 who says juiced? Link to comment Share on other sites More sharing options...
