RedPath88 Posted June 17, 2007 Share Posted June 17, 2007 "Common Sense is poorly named" If you need an explanation, then it describes you Link to comment Share on other sites More sharing options...
Oliver Posted June 18, 2007 Share Posted June 18, 2007 Holy cats! - an exclamation with emphasis on the holy. Sum b*****s! - self-explanatory When asked for advice I usually reply with the old "Don't take any wooden nickels." Several others that have no place on a family-friendly board such as this. Link to comment Share on other sites More sharing options...
vengeful Posted June 19, 2007 Share Posted June 19, 2007 "Posh"Going back a few years if you were well off and on a cruise you would be on the port side of the ship leaving and on the starboard side coming back. "Port Out Starboard Home" (Don't ask me why) It was a term attached to the rich British. In the old days, on cruises to the British Colonies, the boats would sail around the south end of Africa. The port side is the left side, so it had a view of land on the way out, and vice versa. The view-side cabins and staterooms were more expensive than the ocean-side, so only the rich could afford them. The rich would travel in port side staterooms on the trip out, and starboard side state-rooms on the way home, so they could see land. Hence, rich, snobby, upper-class are referred to as POSH. It was explained in my Click & Clack daily calendar a while back, in a segment called Bizzarre British Travel Habits. LOL. Link to comment Share on other sites More sharing options...
TerranoNZ Posted June 20, 2007 Share Posted June 20, 2007 It was a term attached to the rich British. In the old days, on cruises to the British Colonies, the boats would sail around the south end of Africa. The port side is the left side, so it had a view of land on the way out, and vice versa. The view-side cabins and staterooms were more expensive than the ocean-side, so only the rich could afford them. The rich would travel in port side staterooms on the trip out, and starboard side state-rooms on the way home, so they could see land. Hence, rich, snobby, upper-class are referred to as POSH. It was explained in my Click & Clack daily calendar a while back, in a segment called Bizzarre British Travel Habits. LOL. Yeah that's it Cheers for clearing that up Dan Link to comment Share on other sites More sharing options...
fordsho90 Posted June 21, 2007 Share Posted June 21, 2007 (edited) Its on like Donkey Kong......Someone Challenges you. Tight like frog..........A few meanings..1. A tight wad......2. A um sexual experiance You kiss your mother with that mouth?.......A person whom swears like a druken sailor(mostly applies to a hot female) So how do I taste???......um um pretty self explanatory Edited June 21, 2007 by fordsho90 Link to comment Share on other sites More sharing options...
