Swampers On Stock 88 Pathy
gabod7
Got a killer deal on some basically new 32 x 10.5's. i know... search search but i have only have limited access to a computer now because mine finally died. will these 32's fit on my stock 88 pathy?
Here's a pic of mine with 32" BFG A/T's, a 2"- 2 1/2"suspension lift and minor trimming. And here's what can happen if you launch the front a couple feet in the air. You can get away with just a suspension lift, but it'll rub a bit offroad. It might work better of you keep the stock 4" offset size rims though. Mine are 3 3/4".
I ran 32's with a 3" Suspension lift. They would not fit at stock height. Get some JGC coils, and crank the t-bars to get your lift. Keep it on the ground though, or have your fenders end up like JJ's. :tongue:
same thing happend to mine JJ just not nearly as bad and I didn't have flares on it, a few clamps and pulling them the right way put it back to form...some what. It does work but you have to cut.
