88pathylove Posted February 9, 2007 Share Posted February 9, 2007 i woke up this morning and went to start my pathy, it turned over and almost caught then sputtered and wont start, now it will turn over and over but wont catch Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 have u checked the normals...fuel and spark? fuel pump prime up when you his i think its pos 3 on the ignition? should hear a hissing sound from the back... mileage and last timing belt change? i'm assuming the engine is turning over but not doing anything at all Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 i just drove it last night (normily), parked it and this morning it wont start. my feul pump IS turning on so i dont think its fuel. but like i said, it drove normily last night. Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 mileage and last timing belt change? Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 183,000 and i have no idea on the timing belt but had it tuned up about 3 months ago and they didnt say anything about it. Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 (edited) hmm...2 ways to check that really quick...pull the dist cover and have some1 turn the truck over...if the rotor doesnt turn the belt is not on teh pullies anymore...or pull the top cover i think its like 5 or 6 10mm bolts and see if the belt is there and/or has tension... Edited February 9, 2007 by unccpathfinder Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 o yeah it got cold last night, 25F, not that cold but could be an issue. Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 trying right now... Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 just trying to knock things out to narrow it down...i'd do the dist cap check...it shouldnt take 5-10 mins... Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 just tried, rotor spins fine. could be flooded and too cold to evaporate gas but that's just a guess. Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 well thats good then...so t belt is in tact... Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 shouldnt be...the injector will make it mist...hmm possibly pull a plug and wire and turn it over to make sure theres spark getting to the cylinders...also check that the coil wire and all of that is hooked up... Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 getting spark in 1. cant reach rest now(too cold for that) i tryed using starter fuild but no luck. WTF? Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 k...well then maybe the injector is gummed up or something? b/c 25 F shouldnt be anywhere near cold enough to gel fuel...i know it was like 19 here the other day and i didnt have a problem...and my 87 when it was still TBI never gave me a lick of trouble when it was cold Link to comment Share on other sites More sharing options...
Casey.T Posted February 9, 2007 Share Posted February 9, 2007 Codes??? Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 well i couldn't figure it out so its in the shop and hopefully tomorrow we will get to see what it was. i tried pulling codes but its to cold to be out there for more then 30 min. thanks anyways unccpathfinder, but im just stumped and i dont have a shop(freezing) so ill just have to pay. Link to comment Share on other sites More sharing options...
94extreme Posted February 9, 2007 Share Posted February 9, 2007 cold? try high of 0F.. about the same in my garage.. i worked fast. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted February 9, 2007 Share Posted February 9, 2007 well i couldn't figure it out so its in the shop and hopefully tomorrow we will get to see what it was. i tried pulling codes but its to cold to be out there for more then 30 min. thanks anyways unccpathfinder, but im just stumped and i dont have a shop(freezing) so ill just have to pay. 30min?!?! You could have checked for codes in like 3 min. Hope they don't get you for too much at the shop... Link to comment Share on other sites More sharing options...
RedPath88 Posted February 9, 2007 Share Posted February 9, 2007 30min?!?! You could have checked for codes in like 3 min. Hope they don't get you for too much at the shop... Ever checked them in a 2Dr Mr P? *Not 30min, but not 3 either Link to comment Share on other sites More sharing options...
Mr. Pickles Posted February 9, 2007 Share Posted February 9, 2007 Ever checked them in a 2Dr Mr P? *Not 30min, but not 3 either Bah! 2 door, that's your own fault man. Do you have to pull the seat or something? Love the 4 door. Open door, look. Repeat if necessary. Link to comment Share on other sites More sharing options...
RedPath88 Posted February 9, 2007 Share Posted February 9, 2007 (edited) Although possible, I have found it far easier to just remove the four bolts and pull the seat. they have a plastic cover (protector?) over the ECU that makes everything more difficult Edited February 9, 2007 by RedPath88 Link to comment Share on other sites More sharing options...
Mr. Pickles Posted February 9, 2007 Share Posted February 9, 2007 Oh well, its in the shop now. Be sure to post up what they find (or if they don't find anything). Link to comment Share on other sites More sharing options...
88pathylove Posted February 9, 2007 Author Share Posted February 9, 2007 yeah so it turns out its my ignition coil and wires, they want 270 for it, worth it? Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 9, 2007 Share Posted February 9, 2007 i've got a coil thats not that old maybe a year or so...i could sell yea for like $20ish i guess i dont even know what i paid for it off of my 87... Link to comment Share on other sites More sharing options...
RedPath88 Posted February 10, 2007 Share Posted February 10, 2007 they want 270 for it, worth it? No, it's not... the "highest" priced one on partsamerica.com is only $73. And you could get a coil and wires for less than that! Oh, and they are easy to change. Take UUCC's coil and that could drop the cost down as much as $53, depending on what one he has Link to comment Share on other sites More sharing options...
