Harbinger Posted February 6, 2007 Share Posted February 6, 2007 (edited) My my the things you find on teh intarwebs!!!!1!. Linky Link Edited February 6, 2007 by Harbinger Link to comment Share on other sites More sharing options...
88pathoffroad Posted February 6, 2007 Share Posted February 6, 2007 Hot damn. A 900+ lb engine in a 2800 lb Mustang. Insane. Link to comment Share on other sites More sharing options...
NismoSkyZ Posted February 6, 2007 Share Posted February 6, 2007 The only thing that will do is turn heads. It prob gets now traction and has only 500hp from that rediculously large engine....Sweet nonetheless Link to comment Share on other sites More sharing options...
Harbinger Posted February 6, 2007 Author Share Posted February 6, 2007 ......and has only 500hp from that rediculously large engine.... Yeah, but isn't it putting out 1000+ ft/lbs of torque? You don't find numbers like that everyday Link to comment Share on other sites More sharing options...
Casey.T Posted February 6, 2007 Share Posted February 6, 2007 Poor Mustang.... Would be fun to take it down the 1/4 mile, or even a salt flatt run :idea: Link to comment Share on other sites More sharing options...
Harbinger Posted February 6, 2007 Author Share Posted February 6, 2007 Poor Mustang.... Poor Mustang? Poor Sherman Tank! Being forced to live on behind a blue oval Link to comment Share on other sites More sharing options...
=SuperPathy55= Posted February 6, 2007 Share Posted February 6, 2007 that's insane..... :o 55 Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted February 6, 2007 Share Posted February 6, 2007 recockulous...that is all. Link to comment Share on other sites More sharing options...
SC88Pathy Posted February 7, 2007 Share Posted February 7, 2007 My goal now is to have one of these. I won't do anything with it, I'll just have it. Like sitting in my garage or something. Link to comment Share on other sites More sharing options...
Precise1 Posted February 7, 2007 Share Posted February 7, 2007 recockulous...that is all. But 1000+ hp in another mustang is ok ?? At least this is original. He should have put it in a 1 ton truck; it would be decent in the 1/4 mile (considering) and he'd have a frame that could handle some of the torque for towing... B Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted February 7, 2007 Share Posted February 7, 2007 But 1000+ hp in another mustang is ok ?? At least this is original. He should have put it in a 1 ton truck; it would be decent in the 1/4 mile (considering) and he'd have a frame that could handle some of the torque for towing... B 1000 HP is fine in any car...if its able to be put to the ground...but the sheer weight of that engine will slow it down so much it would probably run the same times as a 300 HP car. Link to comment Share on other sites More sharing options...
Harbinger Posted February 7, 2007 Author Share Posted February 7, 2007 (edited) 1000 HP is fine in any car...if its able to be put to the ground...but the sheer weight of that engine will slow it down so much it would probably run the same times as a 300 HP car. Granted a engine built for a TANK will not help your power/weight ratio any. But again, that things putting out over 1000 ft/lbs of TORQUE. Assuming it doesn't just wrench the chassis apart, the thing is bound to be a beast. Paging MWS Edited February 7, 2007 by Harbinger Link to comment Share on other sites More sharing options...
