SLOVAK69 Posted May 9, 2004 Share Posted May 9, 2004 How much oil (in Liters) does my Pathfinder take. Its a 94, V6. Thanks Link to comment Share on other sites More sharing options...
n0cturne74 Posted May 9, 2004 Share Posted May 9, 2004 Usually the capacity for 3.0L v6 engines is 3.5 quarts. Check your dipstick after that point to see what the oil level is. As far as Liters, 3.5 quarts converts to 3.3 liters. Hope this helps n0c Link to comment Share on other sites More sharing options...
statikuz Posted May 9, 2004 Share Posted May 9, 2004 Yeah, if you've got the owners manual [which you prolly don't since you asked =)], it'll tell you all the fluid capacities somewhere in there... Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 10, 2004 Share Posted May 10, 2004 Between 3.5 and 4 quarts total. Link to comment Share on other sites More sharing options...
BigMike Posted May 10, 2004 Share Posted May 10, 2004 what would happen if you put too much? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 10, 2004 Share Posted May 10, 2004 A little too much, probably nothing. Two quarts or more too much, and it'd start burning oil cause it'd be spinning off the crank underneath the pistons and your rings would pull more up with them up into the combustion chamber from the bottom of the motor. Link to comment Share on other sites More sharing options...
somethingcool Posted May 10, 2004 Share Posted May 10, 2004 A little too much will probably cause extra foaming of the oil. Link to comment Share on other sites More sharing options...
SLOVAK69 Posted May 10, 2004 Author Share Posted May 10, 2004 Yeah, thats kinda what I thaught. I put 4 litres in it after the last oil change, and it seems to be doing well. The dipstick was hard to rear because the oil was so clean. Thanks Link to comment Share on other sites More sharing options...
Mr. Pickles Posted May 10, 2004 Share Posted May 10, 2004 3 5/8 quarts, per the owner's manual. Link to comment Share on other sites More sharing options...
