yar1 Posted January 6, 2007 Share Posted January 6, 2007 how do i change the t-case fluid? is this hard to do? do i just use the newest gl-X? Link to comment Share on other sites More sharing options...
nissandoms47 Posted January 6, 2007 Share Posted January 6, 2007 if its an auto you want to use ATF. Link to comment Share on other sites More sharing options...
94extreme Posted January 6, 2007 Share Posted January 6, 2007 not hard, just undo the fill hole first just in case it's a stubborn one. then undo the one to dump. refill with either ATF or GL, depending on the year of your rig. Link to comment Share on other sites More sharing options...
yar1 Posted January 6, 2007 Author Share Posted January 6, 2007 where are the fill holes and dump holes? i dont have the service manual, will it be in the owners manual? Link to comment Share on other sites More sharing options...
nissandoms47 Posted January 6, 2007 Share Posted January 6, 2007 (edited) drain hole in on the front side of the tcase, just look straight at it and you'll see it. fill hole is on the opposite side. its not that hard to see just gotta get under there. you need a 1/2" breaker bar. dont use an impact. Edited January 6, 2007 by nissandoms47 Link to comment Share on other sites More sharing options...
96SE Posted January 8, 2007 Share Posted January 8, 2007 Make sure you can get the new fluid in the fill hole. I was going to do mine the other day and I ended up needing some tubing/syringe. There isn't enough room to tip a bottle up under there. Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 8, 2007 Share Posted January 8, 2007 You can get a screw-on cap with a pump in it or yeah, just stick some tubing onto the tip of the bottle if you can get the tall-boy style with the pointy cap. Otherwise the pump is the easiest, but slowest option. It takes a while to pump thick gear oil out of those quart-size bottles. Link to comment Share on other sites More sharing options...
FUELER Posted January 8, 2007 Share Posted January 8, 2007 for an R50 with VG33 do u recommend GL or ATF? What # viscosity? Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 8, 2007 Share Posted January 8, 2007 Whatever it calls for in the owner's manual....have a look. http://www.nissanpathfinders.net/forum/index.php?showtopic=5410 Link to comment Share on other sites More sharing options...
