Casey.T Posted September 28, 2006 Share Posted September 28, 2006 (edited) We ended up getting something similar to that.... Gas Tank Radiator repair, resistant to Gas and Anti-Freeze.... Guess it was luck I still have the skid in the garage, so when he comes back Sat or Sunday we can make a bigger patch with it Edited September 28, 2006 by Casey.T Link to comment Share on other sites More sharing options...
mws Posted September 28, 2006 Share Posted September 28, 2006 (edited) I can confirm JB Weld works EXCELLENT for gasoline sealing. I had a dirtbike with a weepy petcock. Cleaned it up VERY well (that is absolutely key!!!!) with wire brush and brake cleaner, and then roughed up the surface with 180 grit sandpaper to give the epoxy some "tooth" to grab on to. Cleaned again with electrical contact cleaner (leaves NO residue), and then coated the leaky seam with JB Weld. Let it cure, and it never leaked a drop for the next 10 years the bike was in the family. And to make the repair more flex resistant, get some fiberglass cloth and embed it in the patch. JB, cloth, JB. That makes it a seriously tough and structural patch that will last decades. Edited September 28, 2006 by mws Link to comment Share on other sites More sharing options...
Harbinger Posted September 28, 2006 Share Posted September 28, 2006 I'll vouch for JB weld -- Its holding together a hole in my VW's oil pan, and has been for two years now. Not a drop leaking As MWS said though, just clean the bejezus out of the contact area. (note for my dubs oil pan, I have a replacement, but keep forgetting to buy a 10mm flex socket everytime I change my oil lol) Link to comment Share on other sites More sharing options...
Oliver Posted September 28, 2006 Author Share Posted September 28, 2006 To quote Beanie in Old School, "Still holding! Still holding!" The stuff we got is a two part putty that you mix together and stick on the hole. It is still there and working. -bounce- So the question is should I replace it with that JB patch? And will JB still hold since this leak is on the bottom of the tank at the lowest point? (meaning that it will never be dry unless pulled out and drained.) How's the eye today?? :X I'm surprized I didn't hear one of these :furious: Link to comment Share on other sites More sharing options...
mws Posted September 28, 2006 Share Posted September 28, 2006 If you prepped the tank well before adding the goop (sounds like an epoxy) and it is holding, I would leave it be. If you really want to be sure it will hold, I would grind/sand it smooth, smear on a layer of JB Weld about 1" beyond the putty patch, then embed a piece of fiberglass cloth, and then apply another layer of JB over that. Then forget it! Link to comment Share on other sites More sharing options...
Oliver Posted September 28, 2006 Author Share Posted September 28, 2006 Okey dokey Link to comment Share on other sites More sharing options...
Casey.T Posted September 28, 2006 Share Posted September 28, 2006 grind/sand it smooth, smear on a layer of JB Weld about 1" beyond the putty patch, then embed a piece of fiberglass cloth, and then apply another layer of JB over that. Then forget it! Thats gonna be the Ticket "Still holding! Still holding!" How's the eye today?? I'm surprized I didn't hear one of these :furious: It is several beautiful shades of Purple :X Ill do the warm wash clothe tonight so it will start breaking up... When are you coming to clean the Garage??? oh and the Gutters... dont forget the Pine needles and the cookies Link to comment Share on other sites More sharing options...
QuismO Posted September 28, 2006 Share Posted September 28, 2006 LOL....OUCH!!!!!! Link to comment Share on other sites More sharing options...
Oliver Posted September 29, 2006 Author Share Posted September 29, 2006 (edited) Well, cookies are a comin' Edited September 29, 2006 by Oliver Link to comment Share on other sites More sharing options...
Casey.T Posted September 29, 2006 Share Posted September 29, 2006 We gonna do this tonight?? Link to comment Share on other sites More sharing options...
Oliver Posted September 30, 2006 Author Share Posted September 30, 2006 I should have looked at this earlier, damnit. I skipped work today and everything!! Well I work Saturday and Sunday 6am-4pm. Tomorrow's good after 4 unless you're too beat from Silverwood, you lucky dog. Link to comment Share on other sites More sharing options...
Casey.T Posted September 30, 2006 Share Posted September 30, 2006 I will call you on the way home... Link to comment Share on other sites More sharing options...
