WD21 Idler Arm - Moog design vs stock?
mws
I ordered the L&P stage 3 steering kit and when I went to install it, I finally looked at the idler arm in the '88 and noticed it was not the stock configuration. A little research indicates it is a Moog aftermarket arm.
Instead of the mount having a pin hang extending throught the idler arm,
http://www.rockauto.com/ref/BeckArnley/Det...tml?1014044.jpg
the Moog has a TRE type stud in the end of the idler arm extending up into a cast mount:
http://www.rockauto.com/ref/Moog/Detail.ht...g&K9500_ANG.jpg
Anybody have any experience with this design? My garage floor analysis indicated it should be quite a bit more durable, but can anyone confirm or correct?
Obviously, I could not use the L&P double shear idler arm and brace on this design so I left the Moog. It feels rock solid and I plan to leave it unless someone has history indicating it is a weak design and I should retrofit a stock mount. I am only running 31x10.5's, but play in the desert and want max durability and reliability.
Edited by mws
My Moog IA lasted exactly one off road excursion before it went kaputski. I also roached the stock CL the same day so that might have put additional stress on it. My L&P CL and IA brace set up seems pretty solid. I'd go with the stock design since the Moog one doesn't allow for a brace.
Thanks for all the input!
I have the L&P double shear idler and the brace that came with the stage 3 kit. Based on these experiences, they WILL be going in.
What I don't have is the stock idler arm frame bracket. Anyone have one laying around? And no, Aaron, I don't need any of your "custom" angled jobs! :D
Yes, I have one. I would be MORE than happy to send you one. Used, but in good shape. That be OK? Let me know, and I can send it out Monday.
  • 3 weeks later...
