differential ratio Is it easy to change?
firemandan_nz
Installing gears is the only way to do that and they run about $500 per axle for new ones. You could also look for a wrecked '00-0? Xterra with the 4.9 gears and just swap diffs if they match closely enough...though I bet it'd cost nearly that much to buy diffs out of a X anyway.
I don't think they have Xterras in New Zealand. You'd have to check around if any Navaras there came with 4.9s...
Honestly don't waste your money on getting different gears unless you go for the t-case gearsets that are available.
It's perfectly fine to run the stock diff gears with 33" tires.... spend your money on making the front end more solid to take them without blowing up the centerlink.
