firemandan_nz
Everything posted by firemandan_nz
  1. Well first gear low and high is long enough now and going up to 33" will make it worse transfer case gears could be the go ...Where can I find those?
  2. Ok So I have 31" tyres...If I go to 33" It would make the gears long and low ratio even higher, I have 4.6 ratio and was thinking of changing the diff ratio...Any idea's ps I have a diesel with a lock right
  3. cheers for that...so it must be better to get a LSD for my r180. will diff internals from a rear wheel drive r180 fit inside my r180 front diff?? Cheers dan
  4. Im thinking off putting a r200 to replace the r180 in my diesel terrano...a LSD from a 300zx should fit my current ratio is 4.6 any words of wissdom apeciated
  5. would a manual gearbox and rear diff of a r333 fit a diesel terrano gearbox and front diff??is it the same ratio???
  6. soo...how does one work out the diameter for the piping........
  7. Could some one investigate sending me Jeep Grand Cherokee front coil springs to New Zealand...Ive tryed everywhere Cheers Dan
  8. has anypne put ajustable coilovers in a Pathfinder instead od torsions bars???? to me its makes sence..... what do you think?
  9. Hi all, My name is Dan and im from Napier New Zealand. I have a 92 2.7 turbo diesel manual.
