rollingrock Posted December 21, 2012 Share Posted December 21, 2012 Hey folks I used this thread to install a new 4way plug...but I figured you were supposed to combine the running lights and brake light...well that didn't work. So my question is, should I have a 5 way rather than a 4 way? When I hit the brakes in the day time my dash lights would come on...(Trailer not hooked up) so I snipped those wires on the harness tonight and fixed that problem...but I am thinking I don't need a 4way unless I am doing something wrong. Left Turn Right Turn Brake Running Ground The first post in this thread only lists the following the green & yellow wire is the brake light wirethe pink & blue wire is the driving lights (ya know..when you have yer headlights on...)the gray & blue wire is the left turn signal. What am I missing here? Thanks RR Link to comment Share on other sites More sharing options...
ahardb0dy Posted December 21, 2012 Share Posted December 21, 2012 (edited) you didn't read down far enough, the original post states the following: the green & yellow wire is the brake light wirethe pink & blue wire is the driving lights (ya know..when you have yer headlights on...) should be the marker lightsthe gray & blue wire is the left turn signal.the wire for the passenger turn signal is the gray & red wire. ( on the passenger side) Edited December 21, 2012 by ahardb0dy Link to comment Share on other sites More sharing options...
medicbaldwin Posted January 4, 2013 Share Posted January 4, 2013 with this latest update it still doesn't help my issue of deciding if I want running lights or turn signals. The kit i purchased is all pre-wired just plug and off ya go. Well I plugged in, and my lights are sketchy as stated above. I even purchased a light tester to make sure it wasnt the trailer, turns out it's the plug-n-play setup. just not sure how to rectify the situation? Link to comment Share on other sites More sharing options...
dfather99 Posted April 28, 2013 Share Posted April 28, 2013 Medic did u ever fix this problem i have the same oneand i have the factory kit . Every thing works fine until i turn on the driving lights on. Link to comment Share on other sites More sharing options...
