Flex
turbopath
So, if I disconnect my sway bars will I be able to keep more meat on the ground? With a factory ride on 31's I can crawl up most rocks, but soon find myself with two wheels off the ground and the rig teetering. haha. I really don't want to buy a lift just yet...
Yes, but your road cornering is gonna be equal to a pile of jell-o. (I'm putting mine back till I get a lift.) Also My 31x10.5x15's rub pretty bad and am starting to tear into the front one's. But all in all you will get more flex.
In the front, yes. Noticeable difference in flex (although you still won't get much) and much poorer handling on-road. The rear probably won't add much of any flex since the shocks top out before the sway bar interferes. With no sway bar in the rear and longer shocks it will come out like this...
This "special" setup will be for sale by the end of August. :P
