solid snake Posted August 8, 2006 Share Posted August 8, 2006 I was thinking of buying a dual e-fan rated at 4k, but started to wonder if this was kind of an overkill. Then I saw another e-fan rated at 2,500 cfm, which is 1k more than what I have right now. With the one on right now, when I turn the a/c on the temp stays a little above the half way mark. Then I had a problem with the compressor about a month ago, where a valve ruptured and the freon escaped. The reason for this is that the a/c guy told me that the fan I have wasn't pulling much air and caused the rupture. So now my question is, should I get the 4k or the 2,500 cfm fan? Link to comment Share on other sites More sharing options...
94extreme Posted August 8, 2006 Share Posted August 8, 2006 either the 4k or two (2) 2.5k.. Link to comment Share on other sites More sharing options...
sw Posted August 8, 2006 Share Posted August 8, 2006 bigger the better my friend. go the 4k with the a/c system on the a/c gases heat up & thereofre rise in pressure. air flow helps to cool things down and therefore reduce a/c gas pressure. more air movement the better Link to comment Share on other sites More sharing options...
solid snake Posted August 8, 2006 Author Share Posted August 8, 2006 Yeah, that's what I was thinking too. Thanks for the feedback, now I gotta save $110.00 more to buy. Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 8, 2006 Share Posted August 8, 2006 A junkyard Ford Taurus fan pulls about 3500 CFM on high speed. Mine cost $25. Link to comment Share on other sites More sharing options...
Casey.T Posted August 9, 2006 Share Posted August 9, 2006 I found a Quest Mini Van fan for $125.... Im still shopping Link to comment Share on other sites More sharing options...
solid snake Posted August 9, 2006 Author Share Posted August 9, 2006 A junkyard Ford Taurus fan pulls about 3500 CFM on high speed. Mine cost $25. Is that what they are rated at? Cause I remember a link that took you to fordmuscle.com and they say it's about 2,000 cfm. hell, if they are rated at 3,500 cfm, I'll try to look for one around here, even though it's gonna be pretty hard since there's not too many late 80's early 90's taurus'. before I install that fan, I'm gonna go to the bone yard and try to find a 95 maxima alty. Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 10, 2006 Share Posted August 10, 2006 Shoot, if it'll cool a 3.8 V6, it should be good enough to cool a 3.0. Link to comment Share on other sites More sharing options...
