Slick
Everything posted by Slick
  1. king has a 3" BL and 4" SL and no rear sway bar......... he rides just fine...... just can't wing round corners like i can in mini... but he handles just fine. you can get a 3" BL for almost the same price as a 1".....
  2. i just pulled the filter "up" out of its holder, whipped 1 line off, put that line on the new one, then whipped the 2nd line off n repeated the process... think i lost 2 drops of gas......
  3. go to her profile and click the links. she has a website too full of pics
  4. i usually just yank off the dist cap and put my new wires on it (if they're numbered, or you have to play the "what-wire-goes-where game)...... but i do 1 spark plug atta time..... i check each one as i pull it to see how it's wearing, and i also check the gap...... just to see if the gap had anything to do with whatever, like if it's burnin lean/rich, etc (i'm weird like that) $80 for wires? holy crap. i paid $40 for mine. (i like to shop at kragens a lot) as for the fuel filter, meh, pull it off, put the new one on...... unless you have fuel delivery issues, you won't need to check line pressures n all that jazz.. as for the PCV valve... it's a $3 part, check yours, if it doesn't rattle around in there, ya need to change it... as for the a/c....... erm, the 90 pathy has the "old school" a/c, where you have to take it to be boosted.... unless you went n had the whole system upgraded? for sh!t plug #6, i use 2 extensions and 2 swivels and a 5/8th plug socket with the rubber dealio inside it..... works just fine fer me. there is no mention of a new oil filter? did you get one? remember to let the air filter dry naturally....... ok, i know i forgot something...... *remember to put some oil inside the oil filter before you put it on, and "lube" the seal with some oil too...
  5. looks like a nice truck...... why they sellin it? any maintenance records? R50's are not as "moddable" as WD-21's, but as you can see from the places pezzy goes...... doesn't hurt em much.
  6. must support our very own steveO and rugged rocks off road http://ruggedrocksoffroad.com/
  7. the 2 kids i still have are at 168k and 203k :tonguefinger:
  8. does it happen when you turn or just going in a straight line? or both? more like a "click".... not a steady noise?
  9. if yer in so cal, hit up rugged rocks off road (steve).. he's a member here and RROR is his company...... he knows everyone
  10. not necessarily.. you;d be suprised the symptoms a bad injector can cause....
  11. froggy is from san jose and i'm near stockton, there's 1 in livermore, and a few others scattered around north of here like martin in chico
  12. sorry, what is a mid 80's yota? thanks, coucoui 6 mid 1980's toyota pick up truck i picked my bumper up for $100 and cut off some shanks from a push bar and welded them to the frame and the smittybuilt... i have used it to push trucks and other things around allt he time.. i even used it to knock over a concrete pole
  13. sounds familiar... and mine was a shot injector.....
  14. do what i did.... buy a smittybuilt for a yota (mid 80's) and "modify" it to make it uber strong... hehe
  15. Slick
    Starter Question
    that's what we're here for
  16. Slick
    Starter Question
    cam seals could be shot......
  17. i always remove my faceplate when i am somewhere other than at home or work.... and i hide the remote control. my windows are tinted dark, so it's VERY hard to see my subs/amps. my graphic equalizer is in the glovebox. you could bolt the subs to the floor.... but other than that, as above, if they want them, they're gunna get them.
  18. Slick
    Starter Question
    run whatever oil is best for your pathy.. nothing will stop an oil leak (I should know) have you tried to wipe off all the oil, run er til she gets warm then try to locate the leak? if it's pass side i'd be suspicious of the OPS, valve cover and oil filter yer fine without the tube, i lost mine a while ago and it hasn't hurt anything (and my inner fender mud guards have been missing for years)
  19. well, I only got to vote once, so i voted 33's for King. 4+3=33's mini me jgc lift on 31's
  20. i'm just cooler than the other kids on my block......... cuz nooooooooo one else has what I do
