BoneZ
BoneZ last won the day on June 14 2011
BoneZ had the most liked content!
About BoneZ
  • Birthday 06/10/1980
    I just bought a 91 pathfinder, I plane to make it into a trail Rig
    tualatin, OR
5,247 profile views
BoneZ's Achievements
NPORA Old-Timer (5/5)
9
  1. If you look on creigslist for any major area in the pacific northwest washionton-oregon go to cars and trucks and type in pathfinders pages of them will come up. I dont know if you were looking at shippng one or not though. But the ones over here usally have very little rust compared to ones from other places.
  2. Its simple Kyle Messed with the wiring in it when he had it most likely for the sterio. Then a while after he sold it his butt connector or soter job on the wires came undone. Is that the one that use to have the fox logo on the back window kyle? On a real note I would look at the areas of the harness that splice together. Last winter I was having strange electrical problems and it turned out one of the splice areas had water getting in it and was breaking down the wires so I was getting intermediat groounds all over the place. I simply cut out that section and replaced it with a nice soter job and heat shrink wrap.
  3. very different kind of vidio and a old but good 1. hmm cant get it to embed My link
  4. I agree with this, It is a classic problem with that style 4.3L
  5. Allot of people do it because they put parts on there rig allot of people want and are on a forum that says what state there from and with you licance plate number they can get your address to come over and remove your parts 4 them self. The difference now is when you run that same search your licance number is recorded so if the car is stole and you looked it up they have your name. The problem was massively addressed with that little change.
  6. I had mile markers on the pathfinder in tell the SAS and I ran them hard. They hit stuff, had wheels land while spinning at speed and never had 1 blow up on me.
  7. You forgot the JB weld to make it a complete repair kit
  8. Banned for being nunya I mean why else:)
  9. BoneZ
    Mr Jim
    I stole that chunk from another post I made elsewhere, I would leave the rear axle you have, and just do the front. As for the gear question, you can go with 4:88 in the front and get the 4:90 gears out of a xtera. That is what i did. If you want to spend more money you can get 5:13 for the nissan rear end and the dana 44 but will cost a fair amount of money.
  10. I use regular coke but I agree with slick.
  11. Are you using high temp red loctite on the studs before you install them and giving it time to set up?
  12. BoneZ
    Mr Jim
    To help with the axle thing 1974-1979 Wagoneer, front and rear dana 44's (some 1974-1975 had drum brakes) (rear 44 is offset to clear the fuel tank) (front is passenger side drop)Wrong side drop. 1980-1983 Wagoneer, front dana 44 and rear AMC 20 (it is NOT the weak 2-piece axle type like the CJ's) (front is drivers drop and remains drivers drop until the end of production in 1991)Will work under pathfinder 1984-1985 Grand Wagoneer, front dana 44 and rear AMC 20 (front 44 has a vacuum axle disconnect, try to stay away from this one, swapping it out or removing it and changing the axle shafts is an easy fix though)Avaoid because of vacume disconect 1986-1991 Grand Wagoneer, front and rear dana 44 (rear dana 44 is mostly centered - just a little offset) Best choice for pathfinder SAS.
  13. If you watch top truck challenge 2010 the truck class winner Jason grey, used cutting brakes (cable and handle for each wheel) to take a corner the rigs with rear steering were 2 point turning. Awesome rig to see in person I will try to get a pic of it by my pathy so you get a idea of how big it is if I can make it to summer bash.
  14. Finished getting all the link mounts and links in and got to cycle the front suspension. When I get a front drive line in I will have to limit travel for it.
