Everything posted by Ramon
Hi I was checking the Xterra user manual and the pathfinder user manual mainly the xterra uses almost everything like the pathfinder but what is the real difference in the engine between the VG30E and the VG33E? the size? mileage per gallon? do you know ?
not much about 30 seconds when cold thank you for the advice I will change my oil filter brand
amazing how old is Npora?
this is my engine is the noise is same as yours when starting ?? then I am afraid i have to do a lots of repairs name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" wmode="transparent" style="width:400px; height:326px;" id="VideoPlayback" type="application/x-shockwave-flash" flashvars="">
it is very good!! something like that happened to me some time ago it was the position sensor inside the distributor.I replace it and work again.
What’s the longest drive you have ever had in your Pathfinder ?
Ramon replied to TheCrow's topic in General Forums
uhmm only home-work work-home eventually market or local park I still don´t trust enough traveling so far alone as I live alone and wife so we don´t have family near to travel with and travel alone just not my style and Still many things to repair and fix on my pathy I believe before I can go anywhere I have to finish them. -
And I really appreciate it !
sure no problem and sorry is more like 10 o'oclok the wire no @1
is working is working!!!! thank you very much MY1path!!! I have no way to pay you this
Hi all Well I was changing the head covers gaskets and remove the distributor and I totally forget to mark the position and affected the timing while removing/installing the cap/rotor so now I doesn't start and I don't know how adjust the time of the distributor Is there any way to re-timing it again what do i need to do? help me please
I don't know a lot from models of brands and I can't see the difference as far as I know now the ones I have are Bosch halogen
So now I have normal shock absorbers in order to re use this feature I have to search for special ones with this valving inside ? and I believe those are a bit expensive than normal Thank you
yes is exactly what I am talking the about the oil pressure sending unit called switch in the user manual and nope my oil signal only turn on when I open the switch before start my engine and then goes out may something is wrong with it or the cable is receiving signal some where else I'm gong to star looking for the orange/browm cord to see if is still in the main harness can this oil pressure sending unit cause the engine takes long to start? this happened to me since a while specially when the engine is totally cold in the morning thank you
no pictures because no much room for so, but the diagram below show the location is next to the oil filter below the manifolds exhaust in the right side of the engine
Hello again every one I notice this morning that my oil pressure switch was not connected or plugged anywhere and I search for he cable but didn't found it. I see in the user manual but not pretty sure which one is it Do you know where this signal come from I only found a connector that used to be for the "sport - touring" shock absorber and I search inside but I didn't found any loosen cable to figure out is from there also if you can tell me what is the function of this switch? thank you Jose Ramon
hate a PITA work but I have to do it and yes I got the sealer I only forget to show it LOL is a bunches of things to be removed is a nice suggestion because the Phillips screws are loosen easily may I change them too for bolts too All japanese car use metric bolt nuts and screws??
Oh my I will be very scared if something similar happened to me
Hello everyone I'm here to ask your opinion and help again. I want to replace the gaskets from the head cover of the engine in both sides the only thing I have problem guessing how to remove is the canister hoses that are in the manifold I was checking the user manual but it doesn't show if pressure must be released or special care about it before remove it actually I am not sure is is liquid or vapor in all hoses are under high pressure so here are my questions. If is really necessary to remove it or there is some easy and fast way to do it? Should I remove the pump fuel fuse and star the engine so the fuel pressure releases? the main problem I saw is in the driver seat side cover (USA model) as is under the manifold intake and all that air system Am I missing something else to remove ? thank you for your help Jose Ramon here are the pictures of the oil leaking from there I tighten the screws but the leak still so I decide to replace the gaskets under this is the other side
I am guessing is Auto trans. check sensors some times are not accurate and solenoid valves take long to respond when driving takes long to shift from 1st to 2nd? and if so it do it smoothly or take some work?
...and on mars : http://www.nasa.gov/mission_pages/MRO/mult...a/pia09105.html ... isn't in operation anymore... well... they should have tried our machines !! nice we have a interplanetary vehicle here !!
Hi Eazzrider !!!! Well my pathy is 1990 and I don't know if the sunroof is same size from 4 door for model to 2 door model in all case this is what I snapped for you just in case this is the front edge from the inside I measured from the inside 15 1/2 inches from rear to front this is the edge in the front from outside with burned paint LOL and this what I measured from out rear water seal to front water seal hope this will help is the user manual diagram from the sunroof
Same happened to me I spill water accidentally two days after the same symptoms and also all my gauges went to red the battery, & brake lights the AT oil alert the check engine all at the same time and I though how can be all things breaking at the same time but is a normal caused by Alternator failure I changed the brushes and the coil and now each time I have to work with water near the engine I cover the alternator and distributor with plastic bag to avoid it gets damaged
hi Pezzy Can I also sent you a PM for same issue?
