Everything posted by Coucoui6
anyone know where i can get a strong metal step rail?
Coucoui6 replied to Coucoui6's topic in 90-95 WD21 Pathfinders
here is an update to my current situation... i have a patient that is a contractor and owns a welder ... he is willing to build me some simple but effective sliders with 2" square tubing. i think will have it extend out far enough to be a step rail as well. i think i want only one long 5' square tube with four legs to attach to the frame. i think i will have the rail about 2" to 3" beyond the cab for a foot hold. looking for opinions .... do anyone have comments on the length i want the rail to stick out for the step? and i think a 2" square tubing would look better?" thanks, coucoui 6 -
here is the my totally cheap way to put 31" tires. i cranked up my torsion bars and 1/2" ball joint spacer. and used 2" rubber spacer tabs on the rear. i also re-enforced my rubber spacers with 6" metal hose clamp. now i have cheap stock replacement shock on the front and rear. so to prevent rear sag during towing... i use re-enforcement springs on my rear shocks. ie. homemade coil overs. i also don't have any alignment issues. but my steering components are worn out. i think i will install a steering dampener thanks.
okay .... i found another shop to custom make a slide rail for me for $400.00 on both sides. here is my problem. he only want to use one 1.75" steel tubing to run the length of the cab and matching size tube to weld to the frame. to the frame he will use 4 legs to secure the hold. that is good to increase strength. but will the 1.75" tubing might look funny or is a good enough? i know that steel tubing is very strong. not very sure if that is a good deal? my previous shop just flat quoted me a higher price this time? he was thinking about the cost of newer and nicer jeep or domestic truck, aftermarket part, prices as a comparison. so i know that 4x4parts.com has a slide rail for about that price but i would still have to pay for shipping and for someone to weld it on. thanks for your input. -
your own fabrication looks awesome... too bad i cant do it. can't weld nor do i own a welder. but i can look for a shop to do the same. thanks, coucoui 6 -
okay... i would like to have a step rail and some side protection and ofcourse at a modest price? anyone? ofcourse the side rail must be strong so it will not just fly off or bend in the middle at the first sight of a 4x4 trail. i do get caught in the middle of my frame on tight trails and my wheels are in the air. if i can find one i get i will start making calls for a custom job with 3" or 2" pipes. thanks. coucoui 6
what were you doing to break the cv shaft? did your cv joint break off also or just he shaft? my cv joint make alittle noise but i'm too cheap to replace them. i still need to do alot of other things first. ie. right rear hub leaks.
where can i get a decent bull guard with plate?
put me on the big bear run list.... i've been waiting to go with a group.... a pathy group. thanks, -
do you have a picture of your front bumper from underneath view? thanks. -
A BUMBER MADE IN ARGENTINA by TANOBALDI
Coucoui6 replied to janolopsen's topic in 90-95 WD21 Pathfinders
wow.... that is the prettiest bumper i've seen for pathy's -
best mpg for pathfinder is not to drive it.... consumer reports voted it to be back back in the days but reliability very very good.
At least Toyota dealing with their rust issues, Nissan sucks!
Coucoui6 replied to zack1978's topic in 90-95 WD21 Pathfinders
i got my pathy used and it was from the mid west...ohio originally but ...i just used some flat black spray can and called it a day. i've had my pathy for the last 5 yrs ... just add alittle more pathy and go on. -
hope this works... my pictures posting. -
the skid plate does not extent down that far. it is only to the frame rails. so about a foot in height from the bumper to the frame rails. i can still take the original protective plate off so it does not cover my drain plug. and i still have full turn of my wheels. and your right i'm dont go offroad that hard. i just didn't want to damage my body mount and body alignment anymore that what i've already done. and i did that (body damage) with my old bumper. boy did i come close to damaging my AC radiator. ofcourse.... that could have also lead to my radiator damage too. so i guess my original intent is accomplished. -
sorry, i'm trying to get some pictures on this tread but not successful. i shot the pixs on my camera's lowest settings but still ..... i don't get it. -
hey guys, i know that replacing the cv boot is the best option... but this is what i did and it has worked for me thus far. i use a split cv boot and zip tight every smaller circle of the boot. yes, this is my 2nd replacement passenger side, my original split boot ripped from the little screw tabs. but since it did it this way, both outer boot is doing just fine. food for thought. coucoui6 sorry having difficult time getting the picture on this forum.
Okay .... here is an update ..;.. sorry, i'm at work so no pictures to post, but my new bumper is super strong and ugly. very square with strong angles. my skid plate is also about 3/16" steel at is welded from the bottom of my bumper to the frame rails. i do have one consern. the body mounts are exposed and unprotected ... i know ... in factoy form, it was only covered by a thin piece of metal before and for looks only. but now i'm concerned that i may hit it. my new skid plate is only the width of the frame rails on each side of the pathfinder. do you guys think i need to cover it up with some steel for protection? thanks, coucoui 6 ps i will post pictures later after i get home. -
I really want to thank everyone who posted their experience on this thread... its not very fun playing with a car that no one is interested in or to perserve it. now.... my other two hobbies are my miata and bmw M3... the forums are huge with all types of enthusiest. as for my pathfinder... i dont care to make it pretty just functionally strong. so far me and my little brother have a small competition. 4x4 competition. he lives in las vegas and i live in temecula. so we don't get to go off road very often but when we do. it great fun! all the trash talking begins... as a little boy ... my bro and i used to trash talk with our bmx bikes.... then in college it was mountain bikes... and now its 4x4's or $x$'s. my brother has a 98 toyota 4runner that has 3" suspension lift, rancho shocks, and big 265/70/16 BFG tires. on my last encounter, i only had a 2" cheap lift and crappy 30" tires. but i totally out climb him. i was going up small atv trails that he was getting stuck and loosing wheel traction. so now i'm getting really for the next event. i have better (newer) 31" tires with abit more lift (1/2" upper control arm spacer, re-indexed torsion bars) and with my new bumper better approach and decent angle. thanks, coucoui 6 -
i think my next project will be to add side armor. i would love to have a metal 2" tube or a smaller c channel welded to the frame and sitting just under my doors. how cool will that be! -
i have great news.... i recently found two new 4x4 shops at was willing to do some custom fabrication work on my pathfinder. both of them have never worked on a nissan before but i'm willing to take the risk. one guy was cheaper and one was more but i felt was able to deliver what i wanted. so now the new bumper will only cost me for $300.00, i will have a C channel welded to my frame and a very nice and wide skid plate to protect my front end. this thing is very stong. my radiator will now be well protected. my pathfinder should be ready by tomorrow. i can't wait. i will only have black spray paint but i think that is just fine. this thing should be as strong as an ARB... i also will have 2 bolts welded on top of the new bumper for future jack placement. i don't have any room on my spare tire swing arm because of my gas can mount. so i'm very excited. next time i hit a steep decent angle, i will be very well protected. -
help... i think i indexed my stock t bars wrong.
wow, i just read that tread and it is pretty bad. i hope that dont happen to me! i only have the 1/2" spacers on mine for a few weeks. -
just found steve on the web. yes! i will ask him. thanks
