fritz007
Everything posted by fritz007
  1. you should also update the pics in the signature on your posts the new rims look way better
  2. i just did a quick google search for a Nissan Pathfinder Stereo Wiring Harness and came up with some good picks of the factory set up. Those might help, and they are cheep on ebay. That would be a better set up than just pluggin the pins into the slots because any major bumps and it could cause a short or they could just wiggle loose! Hope that info helps
  3. good idea i will check that out too, i have just had the thing parked in my driveway half torn apart and all grumpy that i have a moldy carpet
  4. Thanks for all the great ideas, it sounds like i will have to rip some other stuff out to find the leak
  5. Recently i vacuumed out the pathy and noticed that under my driver side floor mat(which is rubber) the carpet was soaking wet, and was curious if anybody knows of common leaks in the front driver side area? Any ideas would help water leaks are a pain the A$$!
  6. what is the deal with the back seats reclining in the qx4? i wish mine did that!! the back seats are terrible, does anyone know what years/models these were on and if they would bolt into any other models?
  7. wow u got quite the welcome, way to make an entrance
  8. for sure a switch issue, the wifes headlights were doin something similar and it was the switch. should be cheap to replace or u could pull it and take it apart and look for corrosion that would cause it to short out and actuate the wiper motor... moisture issue maybe with all the snow that u have gotten lately
  9. by chance when looking for a clock spring did u notice if it was the same one for a Qx4?
  10. keep us posted on any info that you find i am interested in starting some projects on mine and performance is number one
  11. if u dont mind how much and where did u get it i think that is the cause of my temp/gas gauge not workin?
  12. huh snapped off the bump stop... that is extreme you gotta quite being a taxi for fat chicks!
  13. put your socket set down and pick up a welder and get crackin on a tube bumper
  14. nice vids, but i am not sure that is your rig, cuz you drive it like you stole it!!!! lol nice racing though
  15. good work and the rig looks sweet with the extra clearance!
  16. i tow my boat around with my pathy and four people in the rig all the time during the summer and i dont have any issues, but if you have the money to spare i would just go with some newer shocks. the air lift would be overkill but could lengthen the life of newer components
  17. just looked on the pinned topics and some of the items have shifted on the nissan help web site but if u seach for a/c blower u can find the topic and to download the info you have to create a log in i.d. which is a good idea anyways cuz they have good information on there about stuff for your pathy like how to fix your sticky seat belts and other common issues but it is worth your time to poke around
  18. check out the pinned topics there is one about the blower motor problems, i had the same issue and Nissan has a kit that you can purchase that has a new motor, and a new blower motor resistor
  19. what was the cost on filter/fluid and how long did it take i am looking at doing this to mine before another summer of boat hauling
  20. i purchased some universal ones from costco that fit pritty good and they have been a life saver
  21. wow next week huh must be in a real hurry
  22. any idea how hard it would be to put this axle under my 02 http://www.nissanpathfinders.net/forum/index.php?showtopic=19342
  23. Nissan Bulletin Blower Motor .pdf is 5th one down http://x.nissanhelp.com/forums/Knowledgeba...p=10&page=4
  24. Started a new thread so no one gets confused with the last thread I had about trying to find some help. I was told that in order to fix my blower motor that would only work on the highest setting I needed to purchase a Blower Motor Resistor, which is correct for Pathfinders that have a manual A/C system however on my pathfinder that has the Automatic A/C it is a whole different set of problems. I had alot of problems finding the blower resistor on my pathy because it doesn't have one. Instead it is equipped with a Fan Control Amp. Nissan has known about problems with this system and have put out a bulletin for them that can be found on Nissanhelp.com. This bulletin has a .pdf page that explains the problem and has a part number for a Blower Motor and Fan Control Amp kit that can be purchased through Nissan. After i received this kit and installed the parts that were included my problem was solved so to alleviate any confusion and problems for people in the future here is some help! 2001-2004 Pathfinder with Automatic A/C
  25. ya, recycle that cat for sure they are almost worth their weight in gold i know in some places there are problems with people crawling under suvs and taller rigs with a battery sawzall and cutting them off to recycle them!!!!!
