Kittamaru
Everything posted by Kittamaru
  1. Not really - it's just above the plug, near the firewall. I can barely get my hand in there, much less a camera
  2. Well... what's the small tube near the #6 plug? Is that vaccuum? If it is... that may well be it - it's kinda degrading a bit and, when I tried to get at plug 6, I kinda disconnected it. I put it back, but it may have fallen out again... I'll have to check it once my engine cools down (was just out)
  3. Another update - I spoke to another mechanic (who works for a company my father used to work at) and he suggested I check my vacuum lines... any merit to this? I priced the EGR valve and O2 sensor... both over $100 here
  4. Update- just filled up today: 230 miles from 17 gallons = 13.5 mpg... I normally average 310 miles from 17 gallons = 18.2 mpg... a drop of almost 5 mpg... UGH I'm giving my mechanic a call monday - hoping over the weekend to do the plugs n wires... then put the truck in next week for a full tuneup + coolant/tranny/oil change. I can't afford to do the 150k mile checkup yet sadly...
  5. Maybe, but it shows that style of engine in both the 4 cyl and the v6 *shrugs*
  6. *nods* I know my Haynes manual says the 1990 Pathy is Carbourated... at least it shows a Carbourated engine with the huge circular air filter on top + some stuff I don't have *shrugs*
  7. Define... Good. It takes about half an hour to reach "hot"... but it gets lukewarm pretty quick *shrugs*. just barely enough to de-frost/de-fog the front windscreen when it's cold out.
  8. I've had no luck finding a FSM that I could snatch - it's always snatched by the time I find it XD Have a '95 FSM, but lil wary of using it
  9. I have a Haynes manual somewhere, that suffice?
  10. I haven't done the O2 sensor yet... and if my EGR is bad it's bad... I haven't done anything to change the backpressure, except patching a long-standing hole in my exhaust (gasket blew between the Y-Pipe and Straight Pipe) I also don't know what the EGR valve is (I think I do, not certain - is it that circular thing near my intake?)
  11. My temp guage never moves from the 1/4 mark... no matter what the temperature (once it's warmed up that is) Think I should check my 'stat?
  12. Seems the truck is determined to prove me wrong - my gas guage is back up to 1/4 again and sitting there, and I'm currently at 200 miles... meh. This is frustrating. If anything, my milage is a LITTLE lower... but I won't know for 100% till I next refill
  13. Timing belt was done less than 25k ago, and was checked last spring. Once I get my paycheck friday I'm going to start the repairs - plugs + wires, then I'll clean and/or replace the MAF. Then put it in for a full tuneup after the new year. What gets me is that it started along with the cold Parts/Sensors I want to replace: o2 Sensor Thermostat Engine Temp Guage Parts I want to clean/check: MAF Heater Core + Plenum Parts I want to install: Bypass + external Tranny Cooler Anything else I'm missing? I mean... I'm basicly 4k overdue for the 150k checkup, just can't afford the damn thing If I could manage to save up two full paychecks I'd be grand, but that requires @!*% to stop going wrong.
  14. Doesn't help mate No idea what that is... to google I go!
  15. Just a quick update - I am loosing mileage... I'm down almost a full 100 miles to the tank... now, part of that could be wintermix fuel (I ALWAYS get worse mileage in the winter, even if I never use 4x4) but DAMN. 100 mile / tank difference? It means I've been cut to almost 70% of my usual MPG (I can normally just squeak 300 miles to the tank without hitting reserve).
  16. From what I can see, the UCA is far too short... you 100% sure that's the right UCA?
  17. No...... but... thinking about it... How hard would it be to alter a pully (eg, weld on a second pully alongside it) and mount a 2nd alternator that's powered off the welded-on pully wheel? Would have to be PERFECTLY straight, but shuold be possible.
  18. That's one guys siggy there... wtf is it? Looks like an ICE, but wtf kind?
  19. Ever consider adding a small, secondary alternator?
  20. I tried googling it, but got a bunch of different results. Any idea on the PA regs for that?
  21. Yeah... Original 18 year old spark plug wires Replaced the Dizzy Cap and Rotor myself about 2 months ago - was damn proud of the fact too I'll try to clean my MAF when it stops pouring hell and freezing ass outside
  22. I won't know about my gas mileage for a while... my gauge doesn't work right until I'm below 1/4 tank (bad sending unit, functions from 100-95% full, then from ~ 30% down to empty I HAVE smelled fuel and something acrid... which has me worried. But the acrid smell and fuel smell started long before the stutter - I attributed that to it running rich due to the cold... was that an idiotic call on my part? As for cleaning my MAF... I haven't. It hasn't been touched since the truck was built Something I should try? The thing to remember - except for the "consumable" parts, and the K&N Air Filter... everything in/on that truck is original from 1990 Consider it good fortune and good craftmanship for everything to last that long
  23. I think my Flares are trapping sh*t and causing my rust problems to become more aggravated... is this a common thing? Any reason not to take em off? Besides the difference in paint colour due to sunlight?
  24. My MAF appears in good condition. I tried wiggling it - no effect. The stutter happens now even when in Neutral and I gas her hard... she chokes and then revs. I called my mechanic - he said that, given I have 18 year old Plug Wires and my plugs have well over 50k on em (possibly even 100k) it's worth a shot to replace em - I planned to anyway. I just need to wait till after christmas (when I get paid next) so I can afford to... Anyone have a recommendation on wires? I'm looking at the NGK's listed in my siggy
  25. It's back again... I'm starting to think it's related more to something being wet than anything... I have recently (as in, less than 2 months ago) replaced my Dizzy Cap and Rotor... should I take those off and look for moisture? right now it's POURING rain, and it's stuttering from dead start up thru 65pmh
