30
PathyGig12 last won the day on October 24 2023
PathyGig12 had the most liked content!
Silver 2001 LE 4WD
2001
Gender
Colorado
Country
2,103 profile views
PathyGig12's Achievements
NPORA Old-Timer (5/5)
282
Jeric411 started following PathyGig12
Maybe some day, but I’m looking to take this old girl as far as she’ll go. She still runs smooth as silk with minimal rust so I reckon I’ve got another 100k with her. Long term I’d love to import a 90s patrol but that’s quite a ways off lol
I’m trying to dig up info on swapping a manual transmission into the pathfinder because my auto is starting to act up finally. It was low on fluid and I added some thinking the problems would go away but I’m still getting a near stall condition pulling up to lights every once in a while. When it’s below 30 degrees it’s also having trouble locking up in drive when I first set off. Does anyone know what differences there are between the manuals and autos? I’ve heard the transfer case is identical but I’m not sure how that works with the AUTO mode dial selector for 4x4. Besides the obvious stuff like running clutch components, and possibly a different ECU, what else might I need to change over? Drive shafts? Sensors? Power valve delete? I may have asked this before, can’t remember, but I’m starting to seriously look into it again.
I’m still running the KYB struts that I installed years ago with AC front coils (~2” lift) Probably due for some new struts soon, maybe next year.
New axles installed and working well. They look more robust than the old ones. I’m glad I did this when I did because one of my inboard Rockford boots had just torn. Still impressive that I got a few years out of them. From what I’ve managed to read on the forums, the Trakmotive axles have a reputation for having issues when used in conjunction with spacer lifts. Something about hitting the strut. Other than that I haven’t found any claims of durability issues. If anyone has a story of these things busting with just a spring lift, let me know! Im hoping the extra range helps them last longer, both the boots and the joints.
Interesting, could you elaborate a little on the axles? I don’t do much hardcore wheeling these days but I’d still be a worried if there are documented durability issues.
Finally back on the forum after a couple years. The rig has stayed roughly the same since my last post, just minor tweaks here and there. Mileage is currently at 373,000. My goal for the truck is to make half a million if I can pull it off. Shes an old ugly workhorse at this point, and I need to address the roof basket at some point because it’s got a good amount of rust. So far the only issue with the truck is transmission engagement on super cold days before the truck warms up. And of course it’s still leaking a lot of oil. I figure this summer I’ll look into a transmission rebuild/swap and address the rear main seal at that time. I was motivated to post again because I just picked up a set of Trackmotive CV axles from rock auto that are supposed to be built with extended travel in them. My goal is to use them so I can safely add an additional 1” spacer to the struts and level out the front a bit. My rear sits a higher even with the tools and spare parts because I’m running the heavy Land Rover coils. Before recently I had no idea these types of CVs existed for our trucks. I’ll update the thread with how it works out.
98dreamer started following PathyGig12
Seat covers are an Amazon special no name brand, nothing fancy. One of a million variations of basically the same thing. I liked this particular look and they were listed as fitting the pathfinder (among many other models) so I figured it was worth a try for the $80ish bucks. The only slight issue is the material bulges out and doesn’t lay flat against the backrest in the middle, but I’ve mitigated it by getting creative with double sided tape.
Wow it’s been some time! I was browsing the r50 section to see what might be new and I figured I might as well throw up an update in case anyone cares. The truck is now at 320,000 miles, still going strong. Worst thing to happen since my last update was an small evap leak, everything else works like new. I’ve got a code for the swirl control system but haven’t been able to track it down yet. Doesn't affect drivability as far as I can tell, so it’s likely one of the million parameters involved in its operation is slightly out of spec for what the system is looking to see. I’ve tested the valve itself and the vacuum lines around it, no issues. Eventually Ill need to sort it out so I can pass emissions, but whatever it’s on the back burner for now. There’s a slight weep from the rear diff, most likely the pinion seal. I need to do the rear wheel bearings, drums, and axle seals all together so I’m planning it for some time over the summer. My girlfriends 4runner needs that same treatment but a little more desperately since her drums are soaked in gear oil so it takes priority over mine at the moment. My engine still leaks oil like crazy, no matter which stop leak I use. I gave up at some point and now I just run maxlife blend 10w-40 which seems to keep it under control better than the mobile 1 did. If I’m driving it a lot every day I go through about a quart per week, but luckily I’m working from home these days so I can keep the oil consumption to a minimum. I also changed the radiator and hoses, along with the two front cam position sensors and fan+clutch as preventative maintenance. Got the front shaft U-joints swapped out and balanced by a driveline shop so there’s no more rumbling on the highway. In the late fall my dad and I took the two pathfinders out to the Logandale trail network outside of Vegas to blast through the sandy canyons a bit. Super fun spot, but my skinny tires were a little bit out of their comfort zone in some of the really deep sand. Especially because the tread depth is getting pretty low. I’ve had the tires since March 2020 I think? So probably 35K miles at least, with about 6-10 months of usable tread left at this rate. My JEGS jerry can go stolen from the back of the truck over the winter. Some bastard cut the ratchet strap while it was parked. People are getting desperate with the gas prices being the way they are. So when I replaced the can I also built in a simple swing open locking mechanism to keep casual thieves from trying. It’s not impenetrable obviously, but so far no one has messed with it. I also got a nice set of seat covers so I don’t have to look at the ugly cuts and tears in my seats anymore. I think they look great now A few weeks ago I welded up some basic low profile rock sliders to help deflect the odd boulder that might want to smack the rocker panels this summer. They mount up using the original mounts for the side steps like most other guys have done. The only exception is the middle bracket had to be modified to get the right height. I tested them with my jack and they’re easily strong enough to use for lifting a wheel. My goal was to lose as little ground clearance as possible, so I made them fit nice and tight to the body, with just enough gap to be able to flex slightly upwards under load without touching. It’s a very basic setup but I’m happy to have that extra bit of protection just in case. You can hardly even tell they’re there In preparation for the season I also swapped out my rusted and damaged smitty trail jack for a hi lift extreme 48” which is much nicer quality and should last forever. I plan to keep it covered in WD40 to keep the rust away and I wipe on a light coat every couple weeks. I’ve padlocked it to the mount just in case Last but not least, I noticed my driver side CV was starting to rattle when I was going over small bumps. At first it sounded like something was loose in the suspension but it turned out to be the inner joint. When I tried to turn the shaft back and forth by hand it had noticeable play. Being that I didn’t want to break it on the trail again like last year, I swapped it out for a new one. The brand is GSP I think? Fairly cheap. Absolutely zero binding at full droop, even with no sway bar, and it’s actually so smooth I had to double check that my hub was really engaged. Time will tell if it lasts, but overall it seems to be good quality. I just wish I had the motivation and time to swap my Rockford boots onto it. From what I can tell, this one seems to be in the pre-facelift style with the round flange rather than the tri-flange shape, which I believe means it should have a slightly better range of motion (provided its made to OE spec) because I think I read somewhere the earlier models had slightly longer struts. Anyway, I think that just about covers everything I’ve done in the last several months. Next up this year Ill be redoing the rear bumper with plate steel now that I have a garage again. Even though mine is still functional, I’m sick of the plastic bumper cover. Then maybe I’ll look into some aluminum skids and a locker. It’s shaping up to be an awesome summer, I’m super excited to hit the trails again.
Yeah it’s kinda funny how they managed to make it the suspension simultaneously so squishy and yet also harsh. My girlfriend has a 99 limited and the rear always sags under any decent weight, but at the same time it’s not comfortable on bumps either. For people who think unibody trucks are crap off-road, they need to take a look at XJs. I do wish the pathfinder came stock with longer travel IFS, but I don’t mind the unibody
Awesome video, glad he made it. I hope RCR sees it and possibly reviews the 3rd gen 4runner soon. I guarantee he’ll be mentioning the pathfinder favorably when he feels how badly those things ride on the road, and how under powered they are in comparison.
Redesigned the bumper tubing and finally added the rally lights. Super stoked right now
Your rotors are original? How many miles? Original post says 220K...... If that’s true I want to know where you source the adamantium rotors and marshmellow pads
I’m pretty sure thats the hose going from the tank to the fuel filter. It’s possible you have a small crack in it thats hard to see and it’s leaking. Definitely try to get a new piece of hose and new clamps to see if that fixes it. Im also wondering if it might be possible your fuel filter is badly clogged and increasing the pressure on the line? But you’d probably have fuel starvation issues if it was clogged to that point
Normally he is more in depth with the reviews, I’m thinking he just has something against the R50. It’s pretty unusual to find one of his reviews where he doesn’t bother to dig into the history or character of the car. This one felt like he took a definitive stance from the beginning and stuck with it rather than weighing each factor individually. But then again his reviews are not really supposed to mean a whole lot, they mainly exist for comedic purposes. Sometimes they’re great, sometimes they fall flat. It’s mainly the cars that he has personal experience with that he gives good reviews, and the other ones he just goes off of a first overall impression and stupid voices to get a laugh. When I first got mine I remember it wasn’t exactly super exciting coming from a small red audi, but the pathys really grow on you the more you use them and modify them. You have to own one to understand I guess
He ripped on it! I was actually coming here to post this vid since it just popped up in my YouTube feed Im surprised he came down so hard on the r50 but not the 4th gen runner, being that they are so similar in style and purpose. I don’t disagree that theyre a bit boring before modifications, but I’m not sure how he concluded it was more boring than any other car in the world?
