Riderman
Riderman last won the day on June 6 2020
Riderman had the most liked content!
98 pathfinder SE 4x4 automatic
Skilled/Experienced Mechanic
46+
Rarely Go Off-Road
1998
Virginia
Riderman's Achievements
Did anybody here know that you can still get OEM parts for R50 pathfinders? Maybe others, I didnt search. For example, you can buy a new Long Block VG 3.3L for $4052.00 or a Short Block for 2800.00? I ordered most of the rubber moldings for my daughter's 98 Pathfinder. Prices are WAY cheaper than the local dealers even with the employee discount. There are at least a couple of places that I found. I used this one. https://www.amayama.com/en You can even get a new OEM Sun roof with gasket/seal for a r50 if you needed one. I spent over 1K on parts that should be here 9-11 May. I'll let ya know.
Won't idle, changed tps & iacv, checked ecu
Riderman replied to Razzmatazz's topic in R50 FAQ's & Pinned Topics
Did the OP ever find the problem? -
Auto transmission - shifting problems when "cold"
Riderman replied to gloer's topic in 96-2004 R50 Pathfinders
That is typically called "morning sickness." I swapped my valve body with a $50.00 junk yard one and it bought me a year or so until I got a rebuilt transmission.- 1 reply
- 1
Removing Engine with Transmission with crane
Riderman replied to ooh180's topic in 96-2004 R50 Pathfinders
Yes it is possible. I did it last June in a 98 SE. -
My hat is off to your mechanic! I pride myself in being a decent mechanic, that one would have taken me a while...OK, a long while to find! LOL I wonder how many people would have replaced the tranny before finding this issue?
If the frame is OK, just go to a JY and purchase a front clip and bolt in on. You can straighten the inner fender parts Close enough to bolt the new metal on using scissor/bottle jacks and a piece of wood 4x4. We have done it many times. Yup, when you pop the hood you can look at the inner fender and tell it's been wrecked before, but NOT from the outside. Just did this for a neighbors PU truck a while back.
I have used both in the past. Black RTV by itself and a gasket with permatex gasket sealer. Both worked well, no leaks.
96 model v6 no spark or injector pulse
Riderman replied to Pathy1996's topic in 96-2004 R50 Pathfinders
Do you have access to a scan toll to read any codes? For example, to see if the Crank Shaft Position Sensor is working or not. -
Hope this helps somebody. We just put a "new" JDM motor/Trans/front differential/Xfer case in my daughters 98 pathfinder a few weeks ago. I replaced all seals, gaskets, etc in each piece. I replaced both Idler pulleys and the fan clutch with new ones I then decided to replace her AC comp/ Expansion valve, dryer, etc. I recharged her AC by wieghing in the exact charge. Her AC was OK driving around town, not bad, not great @ around 80-90 degrees. I purchased some 1/2" rubber HVAC pipe insulation from Lowes for less than $6.00. It comes in 6 foot lengths. I cut it in half, right down the center so I had two 6' pieces. I installed/stuffed it around the outer edge/gap between the radiator and condenser, the top, and both sides. This directs more air thru the condenser at low rpm's, like when it's needed while driving around town. I wish I measured the before/after evaporator temp when I did this, but by seat of the pants feelings, it is MUCH better. My daughter said, "MY AC is Kicking." She told me tonight that her friend stated, "your AC is colder, did you do something to it?" I'll let you know how it works around town in the upper nineties.
About $35.00-$40.00 for the entire dash with the airbag attached from Foss or Pick N pull. I go to both all of the time.
I just purchased the dash out of a R50 with air bag at Pick N Pull here in VA.
Catalytic converter wont pass emmission test
Riderman replied to Shanemccann13's topic in 96-2004 R50 Pathfinders
I had this same issue. I pulled the cat and soaked it in purple power and water from Advance Auto overnight. It's been 3 days and no code/CEL. -
Swapping in an Automatic Shift Transfer Case
Riderman replied to Riderman's topic in 96-2004 R50 Pathfinders
It Fits! The 04 Xterra transmission was Plug and play into my 98 pathfinder.. The only "issue" was the Xterra's transmission wiring harness was a few inches shorter than the pathfinders. I could have easily swapped harnesses but I chose to just move my pathfinders chassis wiring a little and tie wrapped/zip tied them to the speed sensor cable. My pathfinder TX10 transfer case bolted right up to this transmission. I'll make a separate post with a few more details soon. -
The Junk Yards I "peruse" in VA and OH will NOT sell used Cat's.
