13
Everything posted by mickmutante
My freshly bought 1999 pathfinder. Important Maintenance?
mickmutante replied to bolbol's topic in 96-2004 R50 Pathfinders
Don' t forget to change front a rear brake pads and bands... You never know how they were treated... -
Yeah, the bulbs look great... But here is difficult to have access to a JY as in the US... I will look for some used or something to do the experiment... 👍
Mickmutante
Yeah... Maybe in the future I would do just 1" or 2" lift.... But I am not sure... Hahahahaha
Remote entry reprogramming procedures, 96-up Pathy
mickmutante replied to 88pathoffroad's topic in R50 FAQ's & Pinned Topics
I used one of these online instructions... I remember to insert the key 8 times in less than 10 seconds.... Another isuue you need tomknow is the code of the remote... My 2000 Pathfinder was build in december 1999... Somthe code of the remote is KBRASTU09, for Pathfinders made from january 2000 the code is KBRASTU10.... Etc... You have to find out wich code is your remote control... http://www.ehow.com/how_7236224_program-nissan-pathfinder-keyless-remote.html http://freeremoteinstructions.com/nissan/nissan-pathfinder-1996-2008/ -
Welcome DDC03!! I have a 2000 Pathfinder SE Superlux, no lift... I use it with my wife for everyday riding and make trips in the country... We have made 2.600 km trips, with some light offroading... I have been using Firestone Destination AT 265 70 R16, ... For now they have been preforming really good for our needs...
Today I received the led bulb for the Pathfinder fog lights.... They look good... But they do not fit in the case.. The bulbs are too large and the case has a square hole that is too small for the led bulb diameter... I think i am going to make a lamp with them... Hahahahahahah Maybe I can modify the case.. But i do not want to do it...
mickmutante replied to fleurys's topic in R50 FAQ's & Pinned Topics
Year: 2000 LE Superlux Lift : No lift. Wheels : Stock Tires : Firestone Destination A/T (265x70R16) Notes: No other mods, rubbing at full turn on reverse right or left... -
This might be a silly question, but is there an off road cell phone car mount? I have never used one, so I have been looking a lot of those and I really do not know what to buy... Wich car mount do you use? Pros? Cons? Thanks.
To be honest... I don't remember... I put all the tension that the coils allowed... mickmutante - Gallardo
Today I cleaned the "C" ring and washed the belts... I did something similar to this guy... I wash them twice and rinse them 3 or 4 times... Plus.... Re-disassemble the seat belt mechanism... put more turs on the "coil" to get more tension... and reassemble... It worked really well... Now they work like new.!
Cleaned the front seat belts... And it worked! They work like new.
If the sunroof is the same as an R50, the holes are located at the front, on the corners... They might be coveres with mud or debris.... you do not need to take the rubber out... That happend to me... In a rainy day the sunroof star to leak water through the interior onf the truck... the drain holes where covered with mud and debris....
Today I recieved the cabin air filter... The Pathy does not have from factory so I have to cut the air box and do what I have to do to get them installed. I will take some pictures and do a mini tutorial for it. I installed the cabin air filter... The Pathy does not have from factory... I took some pictures and did a mini tutorial. http://www.nissanpathfinders.net/forum/topic/41306-how-to-install-cabin-air-filter-for-r50/
I bought the filter thought ebay... So I need it to be delivered at my house.. but most sellers did not ship to Colombia or the shipping was too expensive... So i bough a really cheap chinese free shipping filters.... The problem was that the filterdoes not fit properly on the box... So... I have to trim some plastic parts and glue them, and glue some foam in the filter to avoid air leaking... 6. The filter set did not come with the metalic "C" clip.. so i took it from the air box. 7. To prevent more air leak, i put some resin between the filters union... I did all the work 1 to 1.5 hours (with the filter modification)... I hope it helps....
My 2000 Pathfinder R50, does not have the cabin air filter, so I decided to install it and do a mini tutorial for it. 1. Unclip the plastic pieces that are located uder the glovebox, they will pop easily. If your Pathy still have the string that holds the glovebox remove it... I did not have.. no photo... 2. Unbolt these 6 screws. 3. Cut the plastic box with a cutter or mototool or hacksawblade, it will brake easily. You have to cut it in the inner line. 4. Clean the new hole and make the filter fit, I did some cleaning with the vacuum cleaner and turning on the fan... I notice that the air box has like a metal filter inside... Just took the picture and continued with the install.... 5. If you have bought the original or non cheap chinese filter just install...
Compared to the Osrams bulbs, how is the "eyesight" or the range with led bulbs? I have read that some led bulbs do no have the range of the hallogen bulbs... mickmutante - Gallardo
Today I recieved the cabin air filter... The Pathy does not have from factory so I have to cut the air box and do what I have to do to get them installed. I will take some pictures and do a mini tutorial for it. [emoji106] mickmutante - Gallardo
Welcome! Do you have photos?[emoji106] mickmutante - Gallardo
To day I tried to fix my front driver and passenger seat belts.. they were to slow... So I search in the forum for intructions, I found them... And disassemble the seat belt mechanism... put more turs on the "coil" to get more tension... and reassemble... and nothing... Still to slow... Next step... I will try cleaning the belt... And cleaning the "C" ring... Some photos during the disassemble...
Wating to have 100 posts... And in few days I will be for 3 moths NPORA member...
For the past 10 days (christmas and new year) we drove 2400km (1491 miles)... and we complete 250666km (155756 miles) on our 2000 Pathfinder R50....
Try to fix the seat belt... but still to low... I think I need to clean the belt and "C" clip...
Lot of work you have in your Pathy... Welcome!
