cntryboy_88
Everything posted by cntryboy_88
  1. I know people have talked about doing this has anyone ever done this that you know of Sent from my SM-N920V using Tapatalk
  2. So I have a 98 with the 3.3 and yesterday I found on Craigslist a 2001 3.5...the guy is gonna sell me the motor tranny and wiring harness/ecu for $500 so I'm pretty stoked about it is there anything more that I would need to make this swap work other than those things? Sent from my SM-N920V using Tapatalk
  3. When I did her black I did spray on truck bed coating then I just used od green rattle can to go over that...so it still has the rough feel to it prevents rust which I have hardly any off and actually does help to prevent against scratches pretty well Sent from my SM-N920V using Tapatalk
  4. So I've been on here for a couple months now I've had my pathfinder aka "Betsy" a little over a year now and I've done a few things to her and I will have a lot more to come here hopefully in the next few months so I decided I would start to post stuff on here as I know many people seem to enjoy reading this stuff (at least I do anyway) so to start I have a 98 pathfinder I got it with 190.000 miles on her and now I'm up to about 204-205ish (my instrument cluster quit working and I got a new one from the good ol JY that reads like 282k) I've added a roof rack pro comp 51 series and 31x10.50x15's...I have a cobra 19 cb on the inside with my 3ft firestick mounted just below my right rear window...I've also added my storage box inside which I did start a post about that...but many more things to come. I want to add a lift with bigger tires Bumpers and Winch HiLift and mount it to the roof rack Rock sliders Double din touch screen inside I'm thinking about manual hubs but have mixed emotions And I'm sure I will think of more later on This is what she used to look like Then she was all black at one time and now this is the color I intend to keep for awhile Sent from my SM-N920V using Tapatalk
  5. I have an android...and I got the scanner for the $25 but it was saying the app you use with it ranges between 0-60 I'm guessing just different features of the app? I saw the torque pro app that's what I'm gonna get Sent from my SM-N920V using Tapatalk
  6. Just ordered this one...what app do you use on your phone...I saw on amazon the app price can go from $0-60 what's that all about Sent from my SM-N920V using Tapatalk
  7. Well that's definitely one way to give yourself some better speakers! Sent from my SM-N920V using Tapatalk
  8. This was relatively cheap I think I only spent around $40 I needed about a sheet and a half of plywood then I used 4 door hinges and the slide out drawer hinges Sent from my SM-N920V using Tapatalk
  9. Finally read all the way through this thread...lots of awesome stuff...I'm on my way to gettin Betsy built but still need some funds! Sent from my SM-N920V using Tapatalk
  10. No it doesn't take up much space at all...it goes right up to the back of the back seat...I might eventually take on part 2 of this build which would be to make it so I could sleep in here I would have to make something that slides out when the back seats are down to make it level with the box...I wanna wrap it in camo to match the rest of my interior...I did my headliner and door panels Sent from my SM-N920V using Tapatalk
  11. I know someone on here has done this before but I don't remember where I saw it...like the idea though so I went ahead and did it over the last couple days finally got it all put together and it turned out pretty awesome...gonna put some camo on it to cover the wood...it has 3 pop up doors on hinges and one slide out door Sent from my SM-N920V using Tapatalk
  12. Is the pricing on KRfabs website in Canadian dollars or us dollars and has anyone ever got ahold of them Sent from my SM-N920V using Tapatalk
  13. Started on this today...seems like you always have a lot of stuff in/on top of your truck...I know someone else did one like this to I saw on here but I'm gonna have a slide out draw the some doors on hinges a long one in the back by the seats then 2 smaller ones on the sides slide out in the middle Sent from my SM-N920V using Tapatalk
  14. Damn that looks like a load of fun Sent from my SM-N920V using Tapatalk
  15. S4 your front bumper is the xj one correct? Did you have to fabricate the piece under(as seen below) it yourself? Sent from my SM-N920V using Tapatalk
  16. Hey thanks everybody for the input...turns out nissan can't draw...hooked the lines up as nissans picture from the stealership showed and the lines were backwards switch them around and started right up! Sent from my SM-N920V using Tapatalk
  17. I pulled the send line off where it goes into the rail Sent from my SM-N920V using Tapatalk
  18. I haven't pulled a plug yet...I'll have to look at the fuses as well...this is just starting to get real annoying Sent from my SM-N920V using Tapatalk
  19. 98 pathfinder....started just fine before...I had a fuel leak from a rusted line so I tore all the fuel lines out from the back to where the lines meet in the passenger wheel well...put the new lines on and they are on correct I've primed the lines I'm getting fuel all the way to the fuel rail but my return line is bone dry when I take it off...battery is good also...any help would be appreciated Sent from my SM-N920V using Tapatalk
  20. 98 pathfinder....started just fine before...I had a fuel leak from a rusted line so I tore all the fuel lines out from the back to where the lines meet in the passenger wheel well...put the new lines on and they are on correct I've primed the lines I'm getting fuel all the way to the fuel rail but my return line is bone dry when I take it off...battery is good also...any help would be appreciated Sent from my SM-N920V using Tapatalk
  21. Ok cool thanks...is it worth buying the kyb struts on their website I just bought new struts and they sell the springs for $180 Sent from my SM-N920V using Tapatalk
  22. Yea but how does that provide 2 inches of lift Sent from my SM-N920V using Tapatalk
  23. So with the ac lift is the strut longer than a stock strut? How does just adding a longer "lift spring" work and not just make it a stiffer ride Sent from my SM-N920V using Tapatalk
  24. Cool thanks for the info...that's pretty much exactly what I want...I like the 35's
  25. I wanna lift my truck 6.5" so I know I have to do the SFD to get the 4" and I keep seeing this 2" AC lift but when I google I can't find nothin about it can someone please give me insight...also maybe anyone who's done the full 6.5" lift total cost for everything and what size tires are you running
