4
mechanicalbaron last won the day on June 3 2020
mechanicalbaron had the most liked content!
About mechanicalbaron
- Birthday 02/13/1974
4x4 3.0L 5 speed manual Pioneer Bluetooth audio. Bass tube. Auto A.C. Polyurethane front suspension bushings throughout. Warn manual hubs. OME. Rear springs. Steering dampener. Factory LSD. AC idler arm brace. AC upper control arms. BF GOODRICH ALL TERRAIN 31X10.50 tires. Rancho RS5000 shocks. Grassroots steering center link. Cobra CB with Firestick 5' antenna.
40-45
1990
Gender
Ventura County California
Country
Interests
Enjoy going to the desert, riding dirt bikes, skeet shooting with the kids! RC airplanes, The family and Beer!
4,146 profile views
mechanicalbaron's Achievements
NPORA Fulltime Resident (4/5)
35
mechanicalbaron started following Parts For Sale
Snow blind. Sent from my SM-G920V using Tapatalk
NOX failure - Colorado Emissions
mechanicalbaron replied to jonrdory's topic in 96-2004 R50 Pathfinders
Interesting, did they give you a printout of the readings? Can you take a pic of it to look at all the numbers? I'm assuming you have similar emissions testing like here in California. Sent from my SM-G920V using Tapatalk -
There should be a small metal pipe that connects to the hose on the bottom of the egr back pressure transducer. Did you remove it and clean the orifice and blow through it? Pretty common for those to be plugged and that hose to be rotted. Sent from my SM-G920V using Tapatalk -
Bike Lane. Sent from my SM-G920V using Tapatalk
mechanicalbaron replied to RedRider3141's topic in The Garage
I've had similar thoughts. Always get hung up with the parking brake. Would love to see a thread on this. Sent from my SM-G920V using Tapatalk -
What are thinking? Had similar thoughts about a center console using an ammo can. Sent from my SM-G920V using Tapatalk -
1. The manufacturer has your vehicle towing capacity. Find out what it is. 2. Boat trailers have surge brakes. Electric brakes and water don't mix. 3. Regardless, if you want a 7 pin trailer harness, put one in. You can get an adapter to operate a 4 pinion harness. 4. If you decide to go with a 7 pin harness you will need a brake controller. I like prodigy. 5. Last but not least, utilize all of your resources to determine what will work for you. Sent from my SM-G920V using Tapatalk
Pop culture. Sent from my SM-G920V using Tapatalk
Put a new starter in her, the original one finally gave up. Only had about 186k mi. and 26 years on it. Think I'm gonna call Nissan consumer affairs and complain. Maybe I can get reimbursed. Sent from my SM-G920V using Tapatalk -
Snow angel Sent from my SM-G920V using Tapatalk
Horse trading Sent from my SM-G920V using Tapatalk
Lazy days. Sent from my SM-G920V using Tapatalk
New ignition switch and front door lock cylinders with new outer door handles. EBAY parts but all worked very well. Sent from my SM-G920V using Tapatalk -
Just last week saw the same issue on a Versa, the main difference being that with an electronic throttle body it was going into a brake over-ride causing a hesitation. Caught it when I was driving it and noticed that the running lights came on when applying the brakes. Doesn't happen often. Sent from my SM-G920V using Tapatalk
Truly amazing. Sent from my SM-G920V using Tapatalk
