byob
Everything posted by byob
  1. hmm. Well the exhaust runs down that side and that is probably what you are feeling. I have never seen a trans generate that much heat to feel from the floor board. As far as the trans shifting if you hear a metalic noise there is no amount of flushing that will help it. There is planetary, one way clutch and other mechanical parts that once they fail its over. The biggest problem with the trannys is heat. If you do not change the fluid or tow alot the life is shortened. The seals in the pump get hard and loose the ability to generate or hold pressure. Usally the first thing to go is the reverse high clutch pack. There is always exceptions of course. My 92 I rebuilt the trans at 135,000 and my 91 is still original with 190,000. But when I do my oil changes at every 3,000 with syn I also do a drain fill on the trans. Just a thought
  2. OK here is a few more pics and of another one that came in today Here is a xe with a home made rack
  3. No it's in San Diego Sent from my iPhone using Tapatalk
  4. Not sure yet. I will go back tomorrow. Sent from my iPhone using Tapatalk
  5. I am converting my 91 to R-134. So I went to the 95 and took the compressor and lines. I noticed a new 90 that just came in. Its a xe but this guy did some work to it. He stuck a 3.3 in it and mounted the alternator up high with a welded bracket. He also had the oem alarm that was not keyless entry. I also took the oem alarm off the 95 to ad to the 91 to make it keyless.
  6. What part of East County are you?
  7. I have had a drill and a rigid break in the stud. Needless to say I went to 10mm studs
  8. Two trains of thought djratlif if iI was in that situation. I would soak the broken stud in PB blaster or the second would be to drill out the stud and retap it. Center punching the center of the stud is very important if you are drilling it out. The studs are actually pretty soft compared to the juke turbo studs that i have to drill out.
  9. I just bought another pathfinder with the typical exhaust leak. Here is your typical 8mm ex stud that break due to stretching. I replace all even though only two are broken. Total time in about 45 minutes. Here it is with the manifold removed. The key is to get a pilot hole close to center. I use a 1/8 drill Here is the tool I use Easy repair
  10. My guess would be a bent rod. You will not get water in the oil unless there is catastrophic damage. Water injestion does not compress like air.
  11. Factory gas caps rarely go bad. You have a gross evap leak. Check the evap system for any leaks. Nissan ses lights have a two trip system. The ecm has to see the failure in two key cycles for the light to come on. You will get a code on the first trip but no light.
  12. Do not put any kind of lube on the belt. Clean the d ring. Seat belts for your truck are life time if they can still be found. Nissan purges their system after 10 years. the vin does take 24 hours to be put back in.
  13. I am a shop foreman at a Nissan Dealership. We just bought a Toughbook c19 that cost $3500 alone. I need to buy a vi and just the basic hardware to get it running. The security card is $400
  14. Actually $1200 is a good shop price. Book time on the repair is 8-10 hours. It depends on the shop rate as far as labor cost. Generally shop rates are $100-$130 a hour. Total parts comes out to around $200-$250 if you want the drive belt. So in the real world $1200 is my good guy price
  15. I will do the repair for anyone on this site or friend $400 otd. The shop charges $1200
  16. I am assuming the shoe is made of harder plastic. The secondary chain is the same unlike the Juke where the chain and guides are revamped as part of its recall.
  17. Make sure it is a lifter not a exhaust leak like 89 said. Will it go away-no. The lifter is starting to collapse or a outside chance it is sticking. What the atf will do is free up a sticking lifter if that is the case.
  18. It depends how loud. Done correctly it will not whine. If it is too tight it will snap a cam or prematurely wear out the tensioner bearing. If it is very slight run it
  19. It is a 07 with 80,900 miles. The engine is really clean internally and the client took good care of it
  20. The client just bought all six coils as soon as I get the drivability done I will get to the rest. C3P has come a long way and $10,000 for the complete kit it better work well
  21. The first pic is with the front cover off and looking at the chain. Here is the reason why. The secondary shoes wear out to the tensioner piston. In this case one of the worst I have seen. The secondary shoes cost $5 a piece
  22. All the dtcs are separate except for the coil and misfire. The target idle speed on mans is 625 and 700 on autos +/- 50rpms. If it keeps coming back try cleaning the throttle body and make sure the tps voltage is below .50 at idle and showing closed. No loads and no one has messed with the factory idle set screw. If all else get a new aicv. I can relearn it for nada. Here is a typical rear main leaking at idle
  23. So a 01 came in yesterday. This is what I see with the 4th gen Nissan Consult. This client has multiple concerns all typical with the R50's. The ign codes are typical in all the 3.5 engines and will cause the p0303. The timing dtc could be caused by low or no oil. The mas could be internal. With the proper filtration cleaning is not the option. In a perfect situation the mas will never need to be "cleaned" . This truck has 180,000 miles and has been poorly maintained. More pics of common problems coming
