helihog
Everything posted by helihog
I need bumpers now! anyone have headway. There was lots of talk on new one being built, what has come of that. I would like to get front and back, preferably from a supplier in Canada, will consider getting them in US. Anyone!!!!
Sign me up, I am in Calgary. Let me know what happens!
With mine I only smell it after I have stopped and gotten out of the vehicle.
I have that as well. It was noticably stronger, a couple years back found it to be a transmision output seal. It was spitting gear oil on the exhaust. :confused: I still get the smell now though no leaks. Most noticable in the winter.
Check out NSOR.com "kit nis 2f-bds" for $474.00 CDN Comes with camber adjustment bolts
Also supply a BDS 2" coil lift, comes with camber adjustment hardware. All for $474.00 CDN
http://www.nsor.com/default.cfm
Thanks
No it, seems we are lacking
Nissandoms47, you would think that it should be that easy. I live in one of the most backward places in the world. I had to take the flyer into a store to show them they carry Rancho!!! :contract: -argue-
I am lloking at the Rancho spec now, the stock shock has 8.5" of travel, the rs9000 has 8.75" not much difference there.
O.K here's what I found out, stock strut #RSX17502&17501. Unfortunately the Rancho Rep says there is no equivalant shock for my 1998 (manufactured 11/97). To get a shock that would travel the additional 2" I would need to modify mounts. Doh! All this to save shipping, taxes and duties. Any ideas,
I am looking for the compatible (rancho part #) strut and shock for the 2" AC lift
Shipping charges are expensive, I want to verify the part number for my Pathfinder that was manufactured 11/97. I explained the shoks and struts would require extra 2" travel, but I think he may have ordered the stock replacement.
Clears shortly after, maybe even before it dries!
It is really strange. must be a short. Anyone have that problem? '98 Pathy.
I am going with Rancho's all the way around (mainly because I can get them locally, lifetime warranty). What are the complaints?
I'm in, sign me up
Mine has been doing that for 100000 KMS, they say its the pilot bushing ($5.00 part, $400 labor). More annoying than critical!
I have that same problem, LSD I run a synthetic gear oil with the LSD additive.
I think I will go with the AC 2" lift (any spacers required on the front end?) Rancho struts and shocks, camber kit, strut boot with bump stop, Nissan strut mount, (strut bearing?), Warn 29091 hubs and finishing off with coil spring rebound bumpers and bushings for all control arms. Can anybody see if I am missing the obvious, or any other sugestions! HH
http://www.gorancho.com/flash/rancho.html Sounds interesting
