alabama_lowlife
alabama_lowlife last won the day on November 4 2017
alabama_lowlife had the most liked content!
About alabama_lowlife
- Birthday 08/28/1979
Former owner of 94 LE-V6 pathfinder
Skilled/Experienced Mechanic
30-35
Do Not Go Off-Road
1994
Gender
Alabama
Country
alabama_lowlife's Achievements
When my negative battery terminal was cracked and loose I had exactly the same problem. Like has been suggested above, check the battery terminals for looseness or corrosion.
Sent my money too
Average cost of SAS?
alabama_lowlife replied to Pathmaker95's topic in Solid Axle Swaps, Hardcore Custom Fab
What part of Alabama are you in? There's a junkyard near me that has a couple HBs and pathys. There are also several of each at the pull a part in montgomery. I'm in the southeast near Troy and enterprise. -
Interior Trim Colors - Sorting out the Madness
alabama_lowlife replied to Dowser's topic in General Forums
I've never seen black, but you left tan off that list. I can't remember the color code for it. I will get the light gray sample to send in since I will be getting light gray for mine. -
I thought it was odd that you were saying there is no relay so I looked at the FSM again, apparently the Canadian models don't have a relay but the US models do......at least for the 95 year. I wonder why they did that?
If you have 12vdc on the solenoid wire (black/yellow?) then there is no need to bypass the ignition or relays. If you've run a new power wire from the battery to the starter. You should do what was suggested above and look at the negative battery cable, look at the strap that grounds the engine to the body as well. It could just be loose, or could be heavily corroded and need replacing.
Rear engine seal: part name or number?
alabama_lowlife replied to WokeUpDead's topic in 90-95 WD21 Pathfinders
The one I replaced was on my dad's 95 HB. Has 281k on it. It wasn't leaking after all those miles! It was the back of the oil pan leaking but we replaced it since we were there and had already bought it. -
Autozone calls it the rear main seal. I put one on just yesterday. -
nice work, that looks really good
whose epoxy-ied their garage floor?
alabama_lowlife replied to unccpathfinder's topic in General Forums
That's nice. I really gotta do that -
Odometer and Speedometer Compensation for 33's?
alabama_lowlife replied to EmptyV's topic in 96-2004 R50 Pathfinders
I don't, but nico has them http://www.nicoclub.com/FSM/pathfinder/ -
I've got some stuff for a 95 pathfinder, but nothing newer -
I've been wanting to do the floor of my shop but just can't bring myself to dump 6-800 on it yet. -
I left you a reply over at infamous, but there are a lot more canadian owners here so they may be able to confirm how the DRL should properly operate. Guys, what i told him over there was that the FSM for a 97 HB explains that the DRL should be off if you crank the truck with the parking brake on. But once you release the brake the should come on and stay on regardless of the parking brake. And of course normal headlights override the DRL. I don't have an FSM for a 93, but on a 90, it makes no mention of the parking brake and it isn't in the wiring diagram. Is the parking brake function common to all years or did they add that at some point? It seems to me like his problem is actually with the passenger headlight NOT turning on with the DRL so the drivers headlight is getting the full 12vdc instead of splitting it with the passenger side.
Other Nissan's with swappable interior parts?
alabama_lowlife replied to ChatWithaNinja's topic in 90-95 WD21 Pathfinders
Any of the hardbody buckets will bolt right up as will the wd21s. The frontier I'm not sure about but they should be pretty close. You can make anything fit with a welder.
