Everything posted by ltsnotme
where did you mount your hi-lit jack?
ltsnotme replied to captandy's topic in 96-2004 R50 Pathfinders
Made it from scrap metal. Jack is 48". -
No, it mounts to the hitch: Yeah, you're probably right. I got the jack as a gift though, and figured I might as well mount it. -
Well, I made this: -
Coil Spring Compressors? Best for the least?
ltsnotme replied to borninabarn's topic in 96-2004 R50 Pathfinders
I know, I meant to come along a few times, but it just never seems to work out I'm keeping an eye on the SCORE homepage though, so hopefully something comes up soon. -
I've used those on the stock front springs with no issues. -
Also, the spring might not be seated correctly. Check if the bottom end of the coil is propped against the notch in the seat of the strut.
I've once wheeled in Grand Canyon: Nothing serious though.
60-80 bucks for the driver side does sound really cheap. I had the passenger side replaced for about that much.
Also make sure there are no cracks in the rubber air duct that leads from the air filter to the intake manifold.
What size tube did you use? I had tried two different tubes when I was replacing my struts, but neither one worked.
Biggest tire for bone stock 04 SE?
ltsnotme replied to PrecisionX's topic in 96-2004 R50 Pathfinders
I have 265/70/15 (~29.6"x10.43") General Grabber AT2's, and they do rub at full lock. Although I don't know how relevant that is considering I have a '96. -
It also depends on the tire and its tread. For any given size, a more aggressive tire will actually be bigger than a highway tire of the same size. -
I think i found my suspension clunk.
ltsnotme replied to ferrariowner123's topic in 96-2004 R50 Pathfinders
I doubt that's what's causing the clunk. I've had that thing bouncing around for a while, until I replaced it with Airlift, and never heard any noise. If it had come off with the metal plate that was holding it up, then it would probably clunk, but since the bolt and the plate are still in place, it's just rubber. -
Which code was it throwing? p0325? Has there been any noticeable improvement in fuel mileage?
Warm up and base line idle procedure?
What app is that? -
Finally thinking about getting a lift..
ltsnotme replied to iPath's topic in 96-2004 R50 Pathfinders
Maybe, but for now I plan on installing 5/16" spacers. I think that'll be enough to clear the frame. What makes it even stranger is that this is the stock tire size for '96 SE's, and I'd thought XE's and SE's were the same, save for the tire size and some other minor options.
