Heloflyboy
Everything posted by Heloflyboy
  1. Tried to figure out how to add side bar to exo-skeleton,without rear door hitting it.HHUUMM.Just does not follow lines.
  2. Very informative.You build some nice stuff.Keep info coming
  3. Build looks great.Radiator looks very clean in that bumper.
  4. If studs are legal where you are,they work GREAT.I use them on my honda civic in the winter time to commute in Lake Tahoe.It gets around as good if not better then 4x4's.I have never tried them on 4x4 though.
  5. I believe the # you want is RS975.I had to cut shafts they were to long.They were only about $30. dollars from Summit Racing it has been a while though so double check.
  6. Nice looking conversion.How is everything holding together with that much H.P.?
  7. I live where it snows in winter and have used lock-rights,detroits and ARBs.I run Rubicon trail every year.This is from my experience.If you drive rig everyday I would not go with detroit locker.It can be a bit of a handful.(I am running detroit now)Lock-rights work well and are inexpensive.I have only broke pins once and that was with 36x14.50x15 swampers.The ARB is best all around(in my opinion)but also most expensive.
  8. Ok I was incorrect I believe if you have a 91 or older it will have lower isolators.Newer models only have uppers.My bad.I looked on energy suspension and did not see anything that would work.I am not saying people have not made something work on the parts list.Here is measurements.This is using energy susp. universal pic. A.3" B.4" C.5 3/4" D.3/8" Hope this helps you might try nissan dismantler.Dealer is probably pricey.Good luck.
  9. The bottom of the spring perch does not come with spring isolator from factory. There is a notch in lower spring perch for spring to set into. Old ford bronco front springs are about same diameter so is a late model jk jeep bottom.I have a set of springs and perches laying in my garage i will take some measurements and let you know what they are.
  10. Hey looks good. Hate when those little projects turn into something much bigger then anticipated. I like the engine combo. Just starting same type of engine swap with auto trans. in a Toyota.
  11. Hey everybody. New to site,looks like a lot of good info. Here is my rig. Next mod is transfer case gearing. www.youtube.com/watch?v=XM-MeBodpq0
