OK. so, I don't want to make a novel out of this as I usually do, so here's what you need to know
My automatic took an official crap the other day. The previous owner had already replaced it, but I guess he wasn't savvy of the trans coolers, so now THIS transmission is bad. I don't want to mess around with a THIRD automatic transmission at 130k miles. (By the way, I know what you might be thinking, but the 2nd trans only had 48k miles on it. installed at 120k)
SO. with that being said, I want to go with a manual. This is for several reasons.
First of all, I can't even find a damn automatic. I just can't find one. I've been to the 3 local junkyards and I can't find any suitable autos. All the nissans are either 5speeds, or have like 300k+ on the clock. Not a likely donor.
Second, I just don't want to deal with the problems of the automatic. From what I understand, everything else is bulletproof on these trucks. The transmission is also, but only with a cooler. I would be perfectly fine sticking with the auto if it had the cooler and none of this happened.
Third, I REALLY do want a 5speed. Not gonna lie.
I've been on several forums and this seems to be the most promising.
What I need help with:
What EXACTLY do I need? Obviously, transmission. But what else? I've gotten the weirdest stuff. As far as I know, I need the transmission, transfer case, clutch pedal, pedal assembly, master cylinder, slave cylinder, the shift boots, fly wheel, pressure plates,
Am I missing anything?
Also, what tools do I need? The seller is pulling the transmission and transfer case for me. But he said anything else I want, I have to get myself. What tools do I need for this? I heard pretty much you can take a Nissan apart with a 10mm, 12mm, and 14mm socket and wrench. Anything else? Some person mentioned I also need 15mm, 17mm, and 19mm?
LAST and more important part
This is currently what is tripping me up
I read that the gear ratios for the rear differential are different between the auto and the 5speed. The auto is like 4.32 and the manual is like 4.62? I don't know exactly, but they are different.
So I thought "no big deal, I'll just buy the rear axle as well", but then someone said "you need the front differential too"
That's a whole 'nother bag of rats. I can deal with the transmission. The transfer case is no problem. The pedal, assembly, master/slave cylinder..etc <- that I can do. I can even do the rear diff, but I don't want to mess around with the front differential. Then I have to mess around with the CV axles and the front differential driveshaft.
What's the real truth? Come on Nissan experts, I need you here!!
Any help would be more than perfect.
Thanks in advance
