peejay
Everything posted by peejay
  1. Touché! The JIS thing never even crossed my mind until after removal, like you said, not seized and low torque spec. In hindsight, I'm willing to bet those injector cap screws ARE JIS, they were torqued down, and I wallowed out many of 'em on removal. Will report back with what Fel-Pro says, but leaning towards aftermarket cushion + cup and roll with it, valve covers shouldn't need to come off again unless I decide to change the timing belt, discussion for another day!
  2. Aw, Slart, why'd ya hafta open up the JIS can of worms??? That came up in another discussion, the member there said "usually" there is a dimple on the screwhead indicating it's JIS, I didn't see one, but at any rate, the #3 phillips "seems" to be an ok fit...for now! "One more" question about this, the aftermarket (Fel-Pro) "Washer Assembly" is of a smaller diameter than the OEM "Washer Assembly", and therefore does not entirely fill the OEM "Tray-Rocker Cover" (what I am calling a "cup washer"). Is that cause for concern? (A reviewer of the aftermarket gasket set stated that they did not use the "Tray-Rocker Cover" when using the aftermarket "Washer Assembly", and I don't feel confident in doing that). I would like to find a "cup washer" that fits the aftermarket "Washer Assembly", but probably doesn't exist, and I should probably not worry about it and reuse the OEM "Tray-Rocker Cover", right? Or do you all only use OEM gaskets? At $9 a pop for the "Washer Assembly", methinks no for me! (Edit: Or, why not place a washer (the same size diameter as the new "Washer Assembly") underneath the new "Washer Assembly", if even that is "required"? What is the "advantage" of the OEM cup-style washer?) (Edit #2: Seems like from other discussions (jeeps), that "Tray-Rocker Cover" is to limit torque, maybe the "cup" portion of it (as opposed to a flat washer) is just to speed up alignment on the assembly line/keep the "Washer Assembly" from moving around...I've emailed Fel-Pro to see what they recommend.)
  3. Great points! I actually bought a 1/4-inch #3 bit socket just for the task, and yeah, the "bolts" were pretty "loose". I'm just not a fan of screwheads (replaced the injector retainer screws with hex heads). I'll make sure everything has been cleaned thoroughly, go slow, and use a torque wrench.
  4. Good eye, slart! Yep, there are slight cracks at various spots along the gasket, normally I wouldn't've thought twice about 'em, but after watching stevexnyc's vids on the subject, it made me go along and actually look for breaks and areas of possible leakage. It looks like I did a crappy job of evenly distributing what I'm guessing is RTV to help hold the gasket in place, this time around I'm gonna clean everything real good and see if the gasket will stay in place without RTV. Ordered some M6x25mm Allen/hex head screws to ditch the Phillips head ones, so got plenty of time to get things in order while I wait for those to arrive.
  5. Sorry it's taken me awhile to get back, thanks for the tips! I did (i think) run my finger along the edge/use a mirror and flashlight to try and see what is mostly likely seepage. (I have a UV light...somewhere...tried it to find a similar leak on my frontier, but never saw the "bright green spots", so gave up on it, plus I'm too lazy to look for it again!) I think I'm gonna replace the passenger's side first, see if my approach works before tackling the driver's side. Are these "bulging areas" of any concern? Should the NEW gasket conform and fill in any gaps? (I did replace these MANY moons ago, and the last time I drove this thing 3+ years ago, I don't recall them leaking (it's smoking BAD now), but it has been sitting for 3 years!)
  6. Greetings, all, Before I go through the trouble of replacing the valve cover gaskets, Is there a sure-fire way to KNOW beyond a shadow-of-a-doubt that they are leaking? I've got (some/most of) the tell-tale signs: - smoke coming from the areas between the valve cover gasket/cylinder head mating surface and exhaust manifolds - vehicle had been sitting for about 3 years - i shoulda changed 'em for good measure when i replaced the injectors (aka, the 3-year injector replacement!) i tried poking around with a flashlight in the dark around the suspect areas, and i could never actually see oil on the manifolds (would i ever be able to?), but my gut is telling me go ahead and replace 'em. (edit...should i replace the passenger's side one first, if the smoke stops, proceed with confidence to do the driver's side one? or pull my pants up and do 'em both????)
  7. Update... FINALLY got the clutch bled ("enough"). A combination of the MityVac, speed bleeder, and old school "two man" method got it done. Ultimately, I think the damper was the culprit, because after "bench bleeding" the master (on-vehicle, using the mityvac), then attempting to use the speed bleeder on the operating cylinder, no fluid ever came out (in hindsight, maybe I didn't pump the pedal enough times, but I felt like I did). After putting the mityvac on the damper, there were MILLIONS of bubbles coming through that section of tubing. I repeated the mityvac method a few times, think I even did the "two man" method with just me a few times, then moved back to the release cylinder/speed bleeder, which produced no fluid at first, then say around 10-15 pumps the pedal got firmer, firmer, then WEAK as I noticed I had emptied the reservoir! At that point I just topped off the master, cracked open the speed bleeder and kept pumping until it eventually built up pressure again, THEN I two-man bled the damper again. Hope to attempt to crank in the next few days and I may eventually do the damper bypass!
  8. You know, hindsight is telling me that I should've started with/suspected the "operating cylinder" all along, in which case I woulda had to drain the old fluid anyway! So guess I'll be draining the new fluid, the pain point is trying to quickly reattach the hydraulic line without crossthreading it! (Edit) I need to take a course in Physics. Just took the banjo bolt out, no more/"new" fluid came out! Moving on to removing the crush washer...(gonna put it in the freezer for a few while I contemplate my life choices!)
  9. Nissan REALLY wants me to do a powertrain swap! Update: Went to put the operating cylinder in, had everything ready so I would lose as little fluid as possible... Got the banjo bolt off, the lower washer off, pulled the bolt up, and BAM! The upper washer was stuck to the bolt!!! ARRRRRGGHHH!!! Rather than remove the bolt and lose fluid in order to assess/remove the washer, I decided "Eh, I'll just order a new banjo bolt". WRONG...guess what is included in the DISCONTINUED list??? So I started with 97-up Frontiers, thinking the parts "should" interchange, well, they do (same part number) which means...DISCONTINUED! 2002-up Frontiers have a different part number, which is available (for now!). Also looked up the banjo for a '94 300ZX (my thinking, same engine/trans, SURELY that bolt has to be the same/similar/good enough to work?) So I ordered two new crush washers (had 2 new ones, but they look suspect), and early and late production '94 Z banjo bolts. Ordered the release cylinder for the Z, too, so when I take the Pathfinder bolt out, I can see if it fits in the Z cylinder. Stay tuned!
  10. Exactly! Lessons learned from letting this thing sit for 3 years.
  11. Ok, I'll be patient, slave cylinder and speed bleeder should be here this weekend!
  12. You know, I bought some of those for the brakes several years ago, never got around to installing them, no telling where they are now. Guess I get to try them on the clutch, thanks for the part number, looks like my local NAPA has 'em in stock! (Would this be beneficial on the damper, too?)
  13. (got the m/c installed, then attempted to use the mityvac to "bench" bleed it, wasted a lot of fluid doing that, then wasted a lot of fluid trying to reconnect the line that didn't want to thread in easily!) raise your hand if you knew that the master cylinder WASN'T the problem??? (gonna bleed the damper next, while waiting on the just-ordered slave cylinder to arrive)
  14. Congrats! My wife would prefer me to "consolidate" my WD21 and D22 into something newer.
  15. That stinks for sure, sorry. You've already got your eyes on another one, though, right???
  16. I thought: right-angle blue bung (leftmost, companion switch mounts under dash) was for CC cancel green bung - (middle) ?? Big blue bung (rightmost, companion switch mounts on support bracket on floorboard) was for starting circuit I'll look at the FSM harness layout section again, see if it gives any clues
  17. Thanks, Frenchy, that worked! I'll admit, I was nervous about using the switches to force the gum drops into the holes, but nothing else was working! I'm more nervous about working on most things on this truck now than I was 10 years ago when parts were more readily available! Oh, what does the "green gum drop" do, since I don't seem to have a switch that it matches up to...is it some cool feature that I don't have???
  18. wait a minute... could it be that the diagram is wrong (or i interpreted the part numbers/dotted lines wrong???) according to the diagram, the GREEN bumper is for the clutch pedal start switch...and the BLUE bumper cancels the cruise control...but based on the size of the "nib" in each bumper, and the sizes of the holes in the pedal mounts, that should be reversed...GREEN is for cruise control and BLUE is for clutch/start circuit? (*** Edit ***) I'm gonna try a hex bit socket pressed firmly against the middle of the button(s)...
  19. Me again... Any sure-fire (easy!) methods for installing the clutch/brake bumpers? Heat 'em in warm water? What I've tried so far: - greasing it, and pushing it on (nope!) - protecting jaws of slip-joint pliers (tape and cardboard, nope!) Next steps: - get a smaller (2") ratcheting C-clamp...i need to go to HF anyway, right???
  20. SUCCESS, ladies and gents! Long story short, I think hammering on the m/c is what did it... The extended version, I used a conical grinding bit on the rotary tool, to dig enough of a groove to get some blows in with the chisel. (Never got close enough to the threads to make a "seam" there). Was getting frustrated at it still not coming loose, turned my attention back to hammering on the m/c from the inside, peeked my head back around and saw that there was more clearance now at the top stud! Then gave it a yank, and voila! Thanks again for all your help and suggested approaches!
  21. Okay, Slart, you've given me more options to consider! (I probably should mention that I like buying (cheap) tools!) - I put penetrant (just liquid wrench) on the hoses, nada...may step up to pb blaster, then kroil, and/or use the picks to get some wiggle room, as you suggested. - got the bright idea to maybe try an oscillating tool, with the blade turned 90 degrees...while it does fit in the space, it is a TIGHT fit, not sure it would do much good, even if I had unfettered access - the dremel right angle attachment came, but doesn't fit the chicago electric rotary tool i've been itching to replace, so picked up one from hyper tough and the dremel attachment fits, so will test that tomorrow - since you mentioned BUTANE, i started looking at those micro torches, found one with an adjustable head, should be here tomorrow (also saw the dremel pencil one, too, but that looks more for soldering, think i may possibly need a flame instead of an "iron" type heat transfer) - may use a mirror to see if the studs are the same whether AT/MT, knocking it out from the front could be an option more to come!
  22. Update...the M/C is STILL on there, but slowly "chipping away" at it: - heat gun with concentrator nozzle didn't work...addition of kroil didn't work, either - had to remove the washer reservoir* and charcoal canister to make more room for the 12" chisel, still a tight fit *was unable to fully remove the washer reservoir...any tips on disconnecting the hoses? seems nissan wants me to break the nibs on the reservoir - the rotary tool was able to make a SMALL "nick" in the ear...ordered the right angle attachment to see if i can get a better angle, may couple that with the flex shaft - this is annoying...
