OlBlue
    91 STICK 95 AUTO
    XE
    CANADA
    Canada
4,272 profile views
OlBlue's Achievements
NPORA Veteran (3/5)
  1. Thanks very much, shouldn't the marks on the crank line up, while the piston is at the top, AND the dist is pointed at #1?
  2. Hi I have started to change the T-belt on a 3.3L the vehicle was running terrible, but made it into the garage. I have the top cover off and can see the t-belt is missing teeth and pretty loose but still in one piece. When I turn the crank, the dist is nowhere near pointing in the direction of the #1 plug, when the timing marks on the crank are near the indicator. I have a piece of wire in the #1 cylinder and can see the #1 piston is at the top, when the crank rotates to align with the timing marks but the FSM says dist should point at #1. Silly question but should I just continue to rotate the crank until the dist/crank line up? Or, is there something I am missing?
  3. Thanks guys, I think I will go ahead and install the AT I picked up, while planning out an eventual swap to MT. Neither of these vehicles have seen a paved road in at least 6 years, and I have to say that I find that the 91 with manual and factory LSD is a far more capable vehicle in snow than the AT without LSD. That is my driving preference, but time is always an issue and the AT swap looks like the way to go. I really want to lock the rear on one of them. Will keep you posted on the trans swap! By the way sorry for the double post, I will look into deleting the other one...no offence ahardboy!
  4. Hi guys, it's been a while. I am looking for some opinions... My 91 M/T is rusted beyond reasonable repair, but has a fresh engine, new clutch. The Auto Trans in my 95 is shot, the engine runs ok but the cam seals are leaking and it is about due for a t-belt change. I have replacement auto trans from a wreck. It seems to me pulling the engine and trans from the 91 and dropping it in the 95, might be the way to go. Both options are a lot of work and either option will get my 95 back on the road just looking for some ideas on the swap. Any takers?
  5. Looked at the auto transmission sitting on the floor I was planning on installing in my 95, then looked out at OlBlue (91-MT) with the rotted frame. Gave some thought to pulling the (fresh) engine and trans as a unit from Ol Blue and installing in my 95, converting my 95 from auto to manual and not completely saying good bye to OlBlue. Made a list of things to consider between a straight auto trans removal install vs diff ratios,, wrestling with front diff, and having to search for that thread about converting an AT to MT, time I have available etc. Decided to go fishing and think it over, ended up thinking about fish...
  6. My 95 only has oil pressure and solenoid (2) wires.
  7. Hi Sorry for the slow response I have been travelling, will post some pics once i get back. Never thought of the window as being an issue since I never use mine!
  8. Since the frame on OlBlue (RIP 1991-2012, 386K) has finally disolved beyond reasonable repair I have been looking at options. I took the plunge today and bought an 03 X -XE. I finally caught on to why everyone is swapping out their 3.0's for the 3.3L...It takes me awhile but what a difference! I like that many of the parts and the "know how" are interchangable between the WD21 and WD22. Lots of good things to say about the X, based on my test drive and inspection. Once I change the t-belt, I need to do something for the front bumper...too much plastic! My 95 WD21 will remain my DD once I swap the toasted trans. Good times.
  9. Good luck man, my 95 was eating starters like crazy last winter and I currently have a Bosch and have had good luck so far. The bolts are easy enough to get to (14mm?) a couple of extensions and then slide it forward and spin up/down/side to side, tilt, turn and if you have A/Twiggle past the lines (fun). Someone posted a while back that they took theirs out from the top after removing oil filter, but I just go through the front. Have at it!
  10. X3 on being built for taller folks, visibility aside with work boots on the tilt steering is the only way a guy can get in/out of a WD21 and get your feet past the pedals.. I am still driving my 95 but since the frame on my 91 has officially dissolved, I am looking at my options. I have a ridiculous amount of parts stockpiled for my WD21's (no spare frames rails though). I have a line on a nice 2003 Xterra, and I am looking into what parts are compatable. It is an interesting exercise, So far I have concluded there are a lot similarities between models,the X has awesome aftermarket options, and the NPORA search function is not the worst ever, the NPORA moderators are awesome and the content on the P-finder site is highly informative onX's! That being said a test ride will tell the tale on my X plans.
  11. Finally took a close look at the rear frame rails on OlBlue. Not safe to drive, not sure there is enough to left to weld anything onto.
  12. Has anyone actually installed these things yet? If so any details? The rear frame on my 91 has all but disolved and I need to figure something out. I like what I have been reading, but wonder if this case is too far along. I will take some pics tomorrow, the amount of decay is remarkable.
  13. I say double check the spline count or you will have some shiny paper weights (like me). If the spline count is compatable bring a pipe and wedge it, if you have access to a cordless impact driver that might also do the trick. (I look for just about any excuse I can find to use my makita.)
  14. Well that ought to do it! I wish I would have though of leaving the PS pump and mount off for the install, that is a good tip 510!
