41
WELCOME TO THE SITE !!
My wife drove my 90 Sentra to North Carolina, when she stopped for gas in Georgia the car wouldn't start it, everything else had power but no start, We thought maybe the floor mat was interfering with the clutch going down enough to engage the switch, well that's what we thought it was as she moved the mat and it started. Once in North Carolina it did the same thing and the mat was out of the way, she got back home Monday night and I drove the car to work on Tuesday, it started fine going to and leaving work, when I got home I shut the car off and tried to start it and it just clicked, not like it was trying to turn over but like it wasn't getting enough power. My question is since it is only doing this when the car is hot could the starter just be on it's last legs? The starter is like the only part of the car that hasn't been replaced since I bought it. when I turned the key to the crank position multiple times in a row the car eventually started. Time for a new one you think?? Thanks all.
my wife had a 88 4x4 with the V6 and we never had any problems with it, I have heard about the head gasket problems but her's ran fine.
One of my co-workers is at his wit's end with this Toyota it is a 92 4x4 pickup, V6, one owner 70K original miles, he says it will be running fine than all of a sudden it will stall out and than run like crap. He has the FSM and has followed all the procedures as to this condition, he has a new coil, igniter, cap, rotor, plug wires and plugs, fuel pump I think he said was new also. He did tell me he pulled the number 6 wire off the cap and it had no spark. I was thinking the pickup under the rotor but he said he tested that and it was ok also. He has no clue on what else to look at , he thinks it may be the distributor but I wanted to see if anyone else had any ideas. Oh, no codes either, thanks
Any Way To Adjust The Rear Wiper Washer Nozzle?
ahardb0dy replied to ahardb0dy's topic in 90-95 WD21 Pathfinders
I fixed it for now, I wedged some plastic shims between the top of the nozzle and the housing, good for now. -
mine did something similar today, I've been trying to get the cruise to work and today on my way home I happen to turn the cruise on and notice the "cruise" light is lit up, I thought wow I haven't seen that before, so I 'm messing with the set and accel buttons and I turn off the highway onto the ramp to turn onto the road that takes me home and when I come to the stop sign I notice the brakes aren't stopping the truck very well, so I make my turn and I'm driving down the road and I notice even when I take my foot off the gas the truck is maintaining the same speed!! So I move the shifter into neutral and the RPM's rise up to about 4000, put it back in drive and they lower back to 2000, it did that a few times, than went back to normal, I guess the cruise was trying to work, fortunately it stopped and made it home ok.
for the fronts on my sentra I filed down an allen wrench to make i square and it fits right in there. -
How To Tell What Gear Ratio I Have In My Truck
wow, that would be really low, didn't think they used a ratio lower than 4.62, don't see anything in the FSM about it either. -
the front ones have a square hole in between the 2 holes, the rear one does not and does not seem to move, don't know, FSM only shows the front type -
Going to change the gear oil in the rear axle, it says it is LSD and has the sticker, what gear oil do you all use? and would you use it again? thanks
Well pulled the 3rd brake light off yesterday, removed the wiper washer nozzle, went at it under the hot water with a pin and finally got what ever was lodged in it out, works great now except the water doesn't come close to touching the rear window, any way to adjust it cause I don't see how it might be done. Thanks
at least the lift supports seem to be working,
I know to look on the tag on the inner pass. fender but don't know what the numbers mean, mine says HG46, so does that mean the ratio is 4.62 to 1? Thanks
Yesterday I swapped out the temp sender for the water temp gauge with the one from the old engine, still reading the same 1/4 way up, so I guess that's normal.
Got Code 35 "egr Temp Sensor" - Solved!
put the sensor in yesterday, had a little hard time getting the plug out than couldn't get the sensor in, had to remove the EGR valve to get some more room, also replaced the spark plugs, the one's that were in there were NGK but they were not the right heat range. No more engine light !! Oh, and the plug for the sensor was there already it just had a cap in it. -
I was checking out some video's on you tube earlier, I'm really starting to like those 500ZX's
I was going to post that ya beat me to it, LOL
any idea what the part number is for those filters?
anyone know how many gallons your supposed to be down to before the light will come on? The gas tank is like 18.3 gallons isn't it? I put 16.8 in mine today and the light wasn't on and I know the bulb works at least still doesn't mean the light works though.
Don't know if my guy checked the timing, he put a new belt and tensioner on, truck runs perfect other than an exhaust leak somewhere, think it may be the muffler I saw some rust on it and it looks like it is the original muffler, I also still have to replace the O2 sensor.
I paid $47 today to put 16.8 gallons in my pathfinder
bought or copied their designs, there were 4 pathfinders at this junkyard, a 94, two 93's and a 92 I think, I know only the 94 had the round dash. And the last Nissan I saw was a Hardbody pickup, talk about stripped it was just the cab laying on the ground, no frame no bed no engine NOTHING, but it had the one thing that made my day, the glove box latch and even though it's not the one with the lock it still fit in the pathfinder glove box and it works !! The wiper washer bottle the 94 had one but the pumps looked like they had been leaking, I got the 2 I took from the 93, the front one looks (and now that I put it in works and no leaks BONUS!!), stil have not come across a good transfer case shift boot or working pneumatic struts. Oh the window rubber on my pathfinder was so brittle it came out in about 10 peices, but the one I bought today went right in with some WD40 to help it.
no, that was from my Hardbody, and it is not from AC it was from Jim Connor Racing, I just stripped the paint and repainted it to use on the pathfinder, I am going to put an original Jim Connor Racing sticker on it after I put it on the truck
home made V-drums, only thing Roland is the drum module, a guy in Minn made the mesh head drums and stand link below, http://edrums.info/
finally filled up the truck today it took 16.8 gallons, drove about 100 miles today and gauge is just below the 3/4 mark
