Igetstabby
Everything posted by Igetstabby
  1. Pretty sure my plate is under the hood, maybe that changed in post-facelift R50s?
  2. Don't go any bigger than 31" without a lift imo. Not only will it rub like hell, it'll look stupid. 31's without a lift fill up the wheel wells just a little too much already.
  3. Nice looking truck... Mine might look close to the same soon (except with fender flares and chilkoot pinstriping ) due to the chrome on my bumpers finally starting to rust.. thinking about going black until I can afford full steel bumpers.
  4. Looks like mph to me - the speedo only goes to 120
  5. Pretty sure there are people on here running 33x12.5 on 3.75bs rims with the AC lift.
  6. Anything is better than nothing I would guess. Nice avatar picture, dev. Good old Immortal... \m/
  7. My buddy just got $5200 CAD for his rotten 97 LE... (He paid like 600 bucks for it almost 2 years ago.)
  8. Depending on how saggy your suspension is it's possible you will have some rubbing at full lock (reverse only probably), nothing taking a heat gun to mould the front of the plastic fender liner wont fix.
  9. Looks about the same as mine, probably 3.75...
  10. Sick bumper... not big on how the gas can holder looks on it, but overall I think this is the best tire carrier/bumper I've seen yet.
  11. The AC camber bolts are supposed to be good for 2 degrees... A little expensive though. Not sure if any other readily available brands give this much adjustment. https://www.4x4parts.com/nissan/camber-alignment-kit-p-2809.html
  12. Not really, my right side rear link is gone and it's hard to get it to make noise when I'm parked. Just get under there and watch/feel for play in the link.
  13. 4" should be about even with the fender flares if you have them... 3.75 sticks out a little bit
  14. That's correct. No auto mode or 4x4 without locking the hubs first and you'll be fine.
  15. You just can't run the "Auto" setting with the hubs disengaged.
  16. Speaking of front swaybar links... Anyone else going through them like crazy? I've replaced my drivers side link 3 times this year and right hand link twice... drivers side is already clunking again less than 2 months later... what gives?
  17. I think the Milemarkers are pretty damn good for being half the cost of the warns. Don't have any complaints with mine so far.
  18. I wouldn't recommend getting rid of the front sway bar, the truck will ride like $h!t and you'll be all over the place. Rear sway bar is less important.
  19. Lots of info and opinions on exhaust pipe diameter here http://www.nissanpathfinders.net/forum/index.php?showtopic=28877 Personally I went with dual in/dual out magnaflow (2.25" pipe). I like it for the most part. Had to sacrifice my spare tire, but the idea is to build a rear bumper/carrier eventually.
