kevs03pathy
Everything posted by kevs03pathy
Yes mine came with the 17's
I just loked at the ad again I think they would be to wide. Might not even be able to hold a bead on my stock 7.5" rims
This link is not an OME lift but it may help with the job. I used it to do my OME struts and springs. http://www.xplorx4.com/pathfinder/upgrades/struts/ If you use it make sure you thank the author xplorx4 he is a member here and on 4x4 parts.com
I saw these on craigs list do you think they will fit my 03 with a 2" lift? and if so what do you think of the tires? http://sfbay.craigslist.org/nby/pts/206919526.html
I'm going to put mine on and see what happens. Hope you get something figured out with yours.
Yes it is. I have been watching your thread to see if anyone has a good answer. Have you tried to get any answers from the manufacturers or the vendors that sell them for our vehicles? I may just put mine on and see if I get the light and then we'll know if maybe it is just you vehicle.
Trying to decide wether to put locking hubs on my 03 pathfinder. I have heard good and bad about puting it on the on the fly 4x4 system. Does anyone have good or bad issues?
I had to have the radiator changed three times because of cracking. I think this last one was an upgrade because I havn't had any problems yet.
So you want to lift your 96-up Pathy?
kevs03pathy replied to BigBikeMike's topic in R50 FAQ's & Pinned Topics
I used THREE of the trim packers (spacers) from Rocky Road Outfitters and it leveled my 03 out perfect. They say the spacers are 9/16" but they measure about 5/16" -
I emailed the folks at OME not sure if I'll get anything back but if I do I will post it.
If he doesn't want your hubs let me know I need a set for my 03
No I just got the coils and the box they came in. I guess you could email them and get the info you want?
I love the new ride not as soft as th oem,but I lve the truck feel. I have gone over some pretty stiff speed bumps at speed and had no topping out.
Which Suspension lift package?
kevs03pathy replied to OR99.5Speed's topic in R50 FAQ's & Pinned Topics
Got my OME setup installed this past weekend. I stacked three of the trim packers(spacers) from Rocky Road. Worked out real good but I think I will have to adjust the camber. I've driven it about 200 miles and it hasn't settled yet. I ordered the camber bolts from AC just in case. -
Went with the heavy springs up front. I'm not sure about the AC lift. I've seen the OME set up without the spacers and didn't like the way it looked so that is why I went with the spacers. I am going to let it settle for a few hundred miles and then have the camber looked at. I'm not sure where to get camber bolts from if I need them. And wether I need them for the top or bottom. I've seen some chat about it here but it wasn't conclusive.
Not sure yet. I have 17" wheels and am not sure what the tallest widest set is that I can get under it? Any Idea's?
Here is my new OME lift on my 03. I used three spacers stacked that I got from Rocky Road to level the front out. The first pic is the before and the next reply is the after.
You can see if this guy will make you some spacers. I hope I am not over stepping the bondries by refering to another site http://www.4x4parts.com/ubbthreads/showfla...sb=5&o=&fpart=1 -
Installing front springs and struts
kevs03pathy replied to kevs03pathy's topic in 96-2004 R50 Pathfinders
Thanks OBX -
Thanks guys I may install the suspension this weekend and wait till I get the hubs to install them. I guess it won't hurt to drive it some before I get them installed. -
Ok guys, thanks for all the help. I have everything I need to do the job,I think? I'm installing the heavy OME front spring with medium in the back. KYB shocks and struts. The spacers I got from Rocky Road are about 3/8 thick,do you still think I only need two to level it out? I just hate to put two under it and then find out I need three. This is one reason I am doing it myself. The other is I have seen what works at my Pepboys,no thanks. Can anyone tell me what the size of the bolts are on the strut? I need to get some to make up for the spacer width when I go back in. I also saw that someone here tacked their bolt heads. I'm guessing that is because they didn't get a press fit and did it to keep them from spinning when you torque the nuts down? I'm trying to find manual hubs before I get started because I don't want to tear up my cv joints. I'm having a hard time finding them for my 03. Anyone have a link? Thanks again for all the help!!!!!!!!!!!! -
I just posted to the garage asking if there is anything special I need to know about removing and replacing my front coils and struts. I am puting on OME springs and kyb struts. I am guessing I just use spring compressors and remove them as an assembley. Is it safe to say that at this point I can remove the strut nut and remove the strut from the spring? Any help would be appreciated.
I am going to be installing my new front ome coils and kyb struts on my 03 pathy soon is there anything special I should know? I plan on stacking 3 spacers from rocky road to bring the front up to level with the back. I will be using the stock stut caps. I am guessing the best way to go about it would be to compress the front spring with spring compressors and then remove the strut and spring as an assembely. Is it safe to say that I can take the strut nut off at this point and remove the strut? If anyone can help here I would appreciate it. I know I will have to get longer suds to make up for the spacers.
I bought a 7" 90deg. adjustable stove pipe elbow at Home Depot and used it to keep the heat off my filter.
