v6engine
Everything posted by v6engine
My cruise control went out this week. The cruise light comes on and that's about it. All fuses are OK. Can anyone tell me where the cruise control module is located so I can swap it
Fill up @$2.97 at Citgo yesterday.
Not the whole diff for me, I just pulled the drive shaft assembly from each side of the donor Pathfinder and bolt it onto mine and change two brake lines. My original diff was the open type (3.25 if I guessed right). I now have an LSD with 3.6 gears. As far as I'm aware, all rear disk Pathfinders come with LSD & 3.6 gear.
11-year-old Bags 1000+ Lb Wild Hog With Pistol
v6engine replied to 88pathoffroad's topic in Off-Topic
An optical illusion or a photoshop trick. The former seems far more plausible. Pretty much case closed to me http://www.cbsnews.com/blogs/2007/05/31/pu...source=flashapp -
Follow up: Nothing mentioned about using different MC (part #) for the rear disk brake or ABS.
I rechecked again and I was a bit hasty in writing last time. This is what I got: Pathfinders and 4WD trucks have a proportional valve in their MC and don't use a load sensing valve Some 2WD and 4WD pickups use a load sensing valve (LSV) and use a different master cylinder. There are only two MCs depending whether an LSV is there or not.
Not sure exactly why? The parts are the same as far as I can see
I check my 1991 service manual and there's only one MC available for both disk and drum setups either with rear ABS or not.
Ditto here. I could not notice any difference in braking.
I did a rear disc swap back in 1999. The donor was a 1995 LE i found in a JY one day. You can either swap the entire rear axle assembly or unbolt each side of the axle with the drum brakes, bolt in the disk brakes and replace the brake line that are connected on the tee fitting. I kept everything else ( ABS, ECU, master cylinder) the same. You can also keep your original diff in the process.
$3.04 at I7-5 and Delk road. It was $3.09 a week ago
What year Maximas are those fans from??
The winning bidder is having second thoughts. He came down to earth and realized how insane he was. http://www.cnn.com/2007/AUTOS/05/10/general_lee/index.html
Seat Diffence Between My Se And Xe(both 95)
v6engine replied to MikeV's topic in 90-95 WD21 Pathfinders
Wait until you're near 40 93path, your back will feel the difference. -
Oh yeah, the seats made for the SEs are a lot more comfortable. My old XE seats were a pain on the back during long trips. When I finally swapped them for the SE types, my back felt a lot better with the lumbar support. -
I wish they had more pictures posted about this one. Can't read japanese, don't know what they're saying. http://page7.auctions.yahoo.co.jp/jp/auction/g55142849
Brakes are fine, nothing abnormal about them. I'll just go ahead and replace the tranny fluid this weekend and check the filter while I'm at it.
Something weird is going on with my tranny. Last January, I brake had to avoid going through an orange light (not to trigger the traffic cam). Once I stopped, I noticed that the truck wouldn't move at all. It appeared that when I stepped on the gas there is no response from the tranny. I would say that some 5 seconds later, the tranny comes back to life and I was able to proceed once the light turned green. I was later able to duplicate the same symptoms in a parking lot. Checked fluids and everything is fine (color, level). Truck is a 2WD 1990 model with over 280K. Tranny was installed in 2004 when the truck had about 263K. I just wanted to know what could be causing this? I planned to change my tranny fluid this spring.
Received just a minute ago.
How about your brake fluid or the connector on the brake fluid reservoir?
the Isuzu had an ugly styling made worst by the plastic trim all around and limited rear visibility.If I recall, it lasted about two years in the market.
Isuzu Vehicross. Anyone remembered that POS? Or how about the Suzuki X90, I saw one a day ago and wondered how the owner managed to keep it from falling apart
No rust here. I always keep an eye on my truck for this cancer.
Thanks Luker. I found the hole on the under side of the alternator. Now I can get to work on the mod. :cool2:
Here's what I mean.
