Astroc2002
Everything posted by Astroc2002
  1. You mean the Eaton M90 Supercharger will bolt right up to the lower manifold which originally mates to the VG33ER heads, but can also bolt to the VG30E heads. If this is true, then I'm seriously having second thoughts about selling my apathy then. Let me know if the bolt patterns are the same on the M90 as the M62. Let me know. Thanx JB
  2. Alright well I know that the air filter is clean, but I'll check the O2 sensor and the catalytic converter. Thanx guys.
  3. Alright, ever since the start of May 2010 I've been trying to sell my 94 Pathfinder LE V6 4x4 with mods. Haven't been able to due to it failing a California emissions test due a high count of Hydro-Carbon emissions. Anyone got any ideas of what it could be... besides the mods done to the engine?
  4. So long N.P.O.R.A. its been an experience being a member.
  5. Thank God I'm not the one experiencing this problem. I own a 94 LE 4x4, and like some of you mine pours water on to the passenger side floor. Now except mine builds all of the water up in the heater box and when I make a left hand turn it dumps in through the fan on to the passenger side floor. So I can't say its a bracket like what ahardb0dy shown us. At first I thought it was the heater core leaking when it rains, so I had a pressure test done and thankfully it didn't leak. But the problem still persists and I'm kinda running out of options on what to do to solve this problem. But I will however save the picture for the future to point out to a body shop to see if water is pouring in through there. I'm just surprised that no one has notified the D.O.T. to file this as a possible safety recall, because the floor on the pass. side would rot out after years of water pouring on to it and staying there, which in result could cause a brutal injury or death to whoever is sitting in the passenger seat. Enough of my ranting. Yes I too checked the drains for the cowl and the sunroof and they're working. Hey ahardb0dy, thanks for adding that picture man. That's really going to help in the long run. :coffee!:
  6. Yeah I hope so too man, because transmission work isn't cheap. But if it turns out to be the transmission you and everyone else might look into this company, they make performance for Nissan's. http://www.importperformancetrans.com/ Good luck man. :coffee!:
  7. Well I'll tell you what it sounds like, if your Pathfinder is equiped with an Automatic Transmission like mine. You might have to take it to a transmission specialist, because it sounds like either you have a gear that's gone bad or the torque converter may need to be replaced. I should know, because I've experienced the same problem in mine... twice. And it could also sound like that computer is adjusting the fuel mixture, hints the possibility to you engine dropping RPM's much like mine. Now has your check engine light been on? Because I've experienced a similar problem on my Pathfinder. Not sure, because I'm not a certified mechanic and I'm not there to experience this problem your having, but I can tell you what I have experienced on my Pathfinder sounds almost the same thing your experiencing. So if there's any mechanics on here that can answer his questions better than me, feel free.
  8. Yeah, eBay offers intake tubes and filters from a unknown company and a company called Jim Wolf Technology offers air filters with necessary hardware to bolt right up to the mass air flow sensor. Now granted the intakes on eBay include an aluminum tube to replace the stock intake tube, however Jim Wolf Technology's intakes hold an Executive Order C.A.R.B. emissions compliant number in the state of California. But from what I've read the ones offered on eBay doesn't mention anything about being smog legal. But should you decide to purchase the intake on eBay I suggest you to message the seller and request to send you the Executive Order number that complies to C.A.R.B. But if your interested in Jim Wolf Technology go to: www.jimwolftechnology.com or visit 4x4parts.com and look under performance parts.
  9. What or who makes the hoohaa steering box system? Because I tried to do a search on Google on hoohaa steering and just got a bunch of forum listings.
  10. OK, for a little while I was driving a 1990 Ford F150 2x4 with rack and pinion steering. I like the rack and pinions response when turning the wheel, so my question is can the rack and pinion from an R50 QX4 or Pathfinder work on a WD21 Pathfinder. Granted its not something I'm going to do right away, I just wanted see what options there are available and write them down you know.
  11. OK, I just wanted to clear that piece up before I do get the 3" Calamini SL and a 3" BL on my Pathfinder. Thanks.
  12. I want to do a 3" body lift to my Pathfinder, but I heard on another forum that when doing a 3" body lift the four-wheel drive shifter can't shift into four low, because the shifter ends up hitting the center console when trying to shift between neutral and four low because the shifter is shorter when doing a 3" body lift. Has anyone here experienced this problem with their Pathfinder? Because I'd like to know if this a true problem.
  13. Hey, who did the Turbo job on this Pathfinder, because I'm tempted to do a twin Turbo job to my Pathfinder.
  14. Well I found out when I partially opened up the heater core box there was a ton of sticks and leaves built up inside the heater core at the base and around it. Plus the bottom of the heater core was damp and the bottom of the box had standing fluid around it. Couldn't tell if it was coolant or rain water, but to be on the safe side my mechanic is going to take a look at it and do a pressure test to see if it is leaking. But if turns out that a lot of the fluid is coming from the A/C box, then I'll take it to an Air Conditioner shop and have them check it out. But again thanx guys.
  15. Yeah I'll give it some thought on going with Schneider 256-H cams, but if by any chance if Schneider wouldn't be able to do your custom cams you might talk to a company called Clay Smith Cams. They custom make cams for almost all vehicles and I'm pretty sure they'll do custom cams for Nissan power plants. Also RC Fuel Injection had told me that the only time I would need bigger injectors is if I'm running aftermarket cams. My brother is running RC fuel injectors in his Evolution 8 while running 272 HKS cams and runs incredible, of course they're 500 lbs. injectors to compensate for the stock Turbo and HKS cams. But I'll double check with RC and see if mild cams need bigger fuel injectors.
  16. I'll actually wait and see how your custom cams turn out and then decide to get a set for my power plant. After I get a set of cams I need to figure out which ECU Upgrade to go with, I'm deciding between Jim Wolf Technology or Jet Performance for the ECU Upgrade. I plan on going with RC Fuel Injectors to compensate for the cams.
  17. I have the very same problem too. I plan on having the nozzle replaced this year and see if that would solve the problem.
  18. What would be considered a mild set of cans? Because I might consider getting my stock cams reground to 260/260 Duration / .420/.420 Lift Z31 Stage 1 kit from thezstore.com or a pair of Nismo .256/.256 Duration / .425/.425 Lift or Nismo 264/264 Duration / .392/.392 Lift from nismoparts.com. Which cams should I go with or what other types cams would you recommend?
  19. Anzousa.com offers euro clear Headlamps for the Nissan Hardbodie (pickup) which can also fit on some Pathfinders.
  20. So my safest bet is to stick with the stock cams considering I just had the engine rebuilt.
  21. Well currently I have the stock OE bumpers which are banged to hell. Will be replacing them this year.
  22. Just curious, I've got a friend who told if I go with larger cams than the stock ones I'll knock off 50k off the engines life. Now could this be possible or not?
  23. Hey man, did you go to the Nissan Dealership in Santa Cruz, because that very same guy gave me a whole run around about how parts for my Pathfinder have to be custom ordered and would cost more. So I quit doing business with them for charging me $305 for not fixing my rear hatch and driverside door sensors for the dome lights(basically make the dome lights turn on and off when the doors are open and closed) and did a bunch of other crap that I didn't even request. But if you want any type of stock OEM parts from Nissan go to www.courtesyparts.com, they have everything that you would be looking for at a decent price. I heard somewhere that Courtesy Nissan has gotten awards in best customer satisfaction. Well check them out man. L8rZ JB
  24. So awhile back I asked a guy on another forum on where he got his bumpers at, he told me to check out Kennesaw Mountain Accessories, so I did and I was very impressed to the point of getting both Front/Rear replaced with custom armored bumpers from this company. But here are the links to their website. One is the main web page and the other shows you what bumper designs they make for Nissan. Enjoy! http://www.kenmtn.com/ http://www.kenmtnac.com/Nissan.html
