Everything posted by govols74n
Actually, since the rod it's self had broken, and I couldn't get the bolts loose, I ended up cutting the bolts off with my grinder and replacing the nuts, bolts, bushings, and the compression/tension rod. I didn't mess with the T-bars, although it might have helped. I used pry bars, foul language and busted knuckles.... honestly.
Does this new bumper make my "Butt" look too big?
govols74n replied to RWC5S2's topic in 96-2004 R50 Pathfinders
But if you go up a steep hill or off of a drop off your tire will hit the ground, that's why you need it higher. -
Actually, if you were to search you would find that I just went through this same problem a few months ago.... http://npora.ipbhost.com//index.php?showto...compression+rod
Looks great Congrats, your a$$ looks great in that. -
I got this off of my local 4x4 club site and I know some of you go to MOAB..(lucky MF's) DO NOT BUY FROM THESE PEOPLE! « on: 03/29/07, 04:25PM » Reply with quote
I like that Titan in your sig....
No kidding....I'll take a look later this week and take more pics for the wiring. Have to mount the Westin lights I just got too.
No new holes in the roof....Already starting to worry about the sun roof seals lol.
Not a silly question at all, I do have the wiring harness, but haven't had time to run the wires yet. Most likely down the track on the stock roof rack to a door sill then on to the engine bay. I might look at it tonight. Not trying the moon/sun roof because then it might leak.
good idea....thanx And, to me, the 6x9 lights do look HUGE, but I guess I will get used 2 them.
SUBLIME... The Wrong Way
Ok, started this thread to show you guys how to use C.B. antenna mounts ($6.00 each from a truck stop) to mount lights on a safari rack or spare tire carrier. I still need to wire them up and paint them flat black. Light tabs are selling in some shops for $40.00 a piece. This is a cheap alternative, although a weld is best. Heres the CB mount You need to remove this part...just un twist Like this Install light like this. sly another What it looks like mounts on rack with 4 bolts, has grooves inside that grip to prevent slipping.
Hey, I had a similar problem when I accidently touched the 2 RCA ends together....blew the sub outputs on the kenwood. I Ended up getting a new stereo, if yours are hooked up they should work.
give it a minute....then listen to the guy in the middle....I still can't stop laughing!
LOL @ the rainbow^^
Welcome!!!!
Looks great! Although it should be orange and white.....Gators fan huh?
It worked for me :secret:
http://www.break.com/index/mcdonalds_drive_through_rap.html
Oh, it's a cell phone holder.....gotcha
Nice....but what's a scoche holder?
Manual 4wd is way better, I personally stay away from the push button crap....
^^^^^was thinking the same
I go to Columbia every once in a while, been there on some doctor appts.
Just checking your research abilities........
