JUDGE
About JUDGE
  • Birthday 02/24/1974
    1997 Nissan Pathfinder LE 4X4 Automatic Green exterior w/ grey leather interior Brush Guard from a 2002 Pathy Fleury's Skid Plate 2" AC lift w/KYB struts & RS5000 shocks Warn manual hubs 15x8 Cragar "Sixers" w/ 31" GoodYear Territory Cobra LTD29 Classic CB 4x100watt front spots & 2x100watt rear floods K&N CAI w/ DryCharger wrap
    Skilled/Experienced Mechanic
Contact Methods
  • Website URL
    http://
  • ICQ
    Ottawa
  • Interests
    Fishing, Golf, Cigars, Fixin' stuff
4,721 profile views
JUDGE's Achievements
NPORA Fulltime Resident (4/5)
  1. I hope you remembered to add a bottle of LSD lubricant to the rear diff before filling it with gear oil.
  2. Until you install the other warn keep the one you have on locked and all should be fine. When installing mine I double stacked the nuts to tighten the studs. I didn't measure the force just went with feel. I used lock-tite as well. Maybe some are not the same lenght because they're not tight enough. HTH!
  3. I assumed that was the reason, between me and the fuel tank being on that side it would make sense. I just wanted to know if anybody else had the same issue. Thanks!
  4. I notice my passenger side top out more than the driver. Does anyone else have the same scenario?
  5. Lookin' foward to May 1st weekend!!!
  6. I changed my filter when changing the fluid. For me, it's peace of mind knowing it's been replaced.
  7. I used a screw driver and a hammer. I hit the flange in different spots to shock it and then tapped it out with the screw driver to separate it from the hub. HTH!
  8. Welcome to the club! Regarding your hard starts: I would also recommend changing your fuel filter. Before changing mine my truck took (in my opinion) too many turns to fire, after the new filter it fires right up. I think a full tune up would be a good idea aswell, your truck will run better and you'll have the peace of mind knowing when it was last done. Best of luck!
  9. Looks good! I can't wait to put my lift in, just waitin' on warm weather.
  10. There's an info plate inside the engine bay, on the passanger side I believe, that has your gear ratio etc.
  11. That's the route I'd like to go.
  12. X3 For me if there's snow on the roads it's in 4WD, especially when I'm driving on the highway. Glad you made out ok.
  13. Nice to meet ya buddy!
