jammer
Everything posted by jammer
  1. Below 10 volts eh... same thing happens to me but it's when I go over 10 beers. Thanks again for the help. Got the Alt. out no problem tonight. The hard part is finding a new/used one in this small town.
  2. I figured it was the alternator so I'm glad you agree. I was just curious as to why the three lights came on instead of just the battery light which is what I thought should happen if it was just the alternator. It just freaked my out to have three lights for three completely different systems on the truck go on at the same time. Now that I 'm done work I'll roll the Pathy into the garage and get to work.
  3. While driving yesterday three of my indicator light starter to flicker at the same time and now they are on all the time together. The "brake warning" light, the "A/T oil temp", and the "Charge warning" light are all on now. Any ideas? There is nothing in the owners manual (I know but I had to look) and nothing in my repair manuals. There aren't any garages open today where I live and I need my ride for work.
  4. Got the e mail! Keep up the hard work on this kick ass site!
  5. I'll definately try all these suggestions. I only wish I had noticed it a few months ago as this AM we were sitting at -22 C. I'll have to see if I can find a kind heart with some heated garage space. Thanks again
  6. I bought another 95 Pathy and since it is in much better shape then mine my wife claimed it! Now I only get to drive it when I can sneak away without her knowing and every time I do I find or hear something that's different then mine and have to investigate. The first issue is with the tach. It never worked from when I bought it. It was pegged out at the max, even when off, and never moved except when it was floored and then the needle would jump back about 1000 rpm. While driving I was doing some diagnosis the other day on it but didn't figure out anything more then I already knew. The next day I got in and the tach started working :confused: Has this happened to anyone else? The other issue is a slight hum that comes from the back end while driving. The hum is faint but can be easily heard. It only hums when the accelerator is pushed. When I'm coasting no noise but as soon as I touch the accelerator, even ever so slightly, the hum starts. The hum sounds like new knoby tires but obviously it isn't that. It can be heard from around 50 kph (30 mph) to around 100 kph (60 mph) as road noise cancells it out at that point. Does change slightly with speed. I appreciate all your help as the closest dealer is 2 hrs away and I have not had much success finding a good mechanic locally.
  7. Space is a true premium in a Pathy when travelling especially when you have two little kids like I do. I have removable Thule roof racks and a rigid Thule box. Both are great as the racks have feet made specifically for a Pathfinder so they are bomb proof. The box is nice as it keeps things dry, is more arrowdynamic then a bag and is lockable. I use it mainly for camping and skiing (we do a lot of both) but will be strapping it on for the Christmas trip. If it's something you think you might use a lot like I do it's worth spending the extra $$. If not go with the bag.
  8. I hear your pain but they are generally GREAT machines. Have you tried any conditioners or treatments yet? I had a problem shifting into R and eventually lost it altogether. Also had hard shift from 1 to 2. A customer of mine rebuilds tranys so I asked him. He said try the conditioners first as working on a Pathy trany is a bitch. I can't remember the brand I bought but basically he said the "O" rings may have small cracks in them causing pressure problems and the coinditioner softens them up and cures the problem. Fixed mine up 95% so I was very happy! I just drained the system and added new fluid and the additive. About 30 min max! Hope that helps.
  9. I've been plowing now for three years and have been runing the wires out from under the hood and into the front seat through the passanger window but would like to do it proper and punch it through the firewall. Has anyone done this and if so where is the best location? BTW if anyone is looking for a plow mine is made by Snowbear and it's great. It's light duty but has easily handles 18" of snow and more. The mounting bracket is made for a pathy so no drilling, just bolts right on. Plow is raised and lowered by a winch which is on the plow bracket not the truck and can be manually angled left or right. Bought it at Crappy Tire (AKA Canadian Tire) for around $1000 if I remember correctly and it paid for itself in the first year.
  10. Easy and free eh! The same way I like my dates! Thanks for the good advice. Much appreciated! I'll try pulling the belts tomorrow. Lets hope that finaly figures it out.
  11. jammer
    Speakers
    Now gee...having wiring universal would be just too easy. I actually took it out one day and pulled what I could apart but couldn't find anything that look broken. Put it all back together and low and behold the display worked...for 2 days.
  12. jammer
    Speakers
    Have ya tried the volume control?!?! I ran into a similar problem when I installed a nice Sony system in my boat and I did what NC95 suggested and got an old speaker and wired it directly. Found out it was a problem with the harness. Cheap fix and no wire pulling required. Now if I could just get the display to work in my stock radio I could actually tell which station I'm listening to.
  13. Ok guys...lets get back on topic here! I did the smoke thing and there was no obvious movement of smoke. Even cleaned out enough of the garage to do it inside. I'm not sure if the sound I'm experiencing is the same as yours SuperSon as mine is more of a mehanical sound like a moving part needs lube ect. It has a beat to it (bear with me here as I don't know how else to discribe it) like two "swishes" every second. This makes me think it is something driven by a belt. As I said my first Pathy did it for 7 years so I don't think it's a big deal except it is noisy at idle. I've tried like crazy to track it but can't figure it out. There has to be a fix as the new engine on Pathy #1 doesn't do it. It was the first thing I noticed when I picked up the truck from the garage. Any ideas on a diagnosis proceedure? Thanks.
  14. I searched past topics but didn't find anythying on this. I just bought another 95 Pathy (auto LE) and there is a noise that constantly comes from the engine compartment. The best way for me to discribe it is as a constant swishing noise. It isn't the manifold issue for sure. The nosie doesn't seem to increase but due to road noise ect you can't notice it at road spead but it is always there at idle. Warm, Cold, wet, dry doesn't matter. Now I had the same sound in my other 95 from day one and the Nissan dealer could hear the sound but said it is was normal. Had to install a new engine (don't ask) and the new engine does not make the noise. So now I know my new one should not make the noise but can't figure it out. Any ideas?
  15. OK here is a tip for everyone who has an older vehicle that is starting to cost them $$ and they are thinking of ditching it. On a nice sunny day go and stand infront of your vehicle and in a nice but stern voice say "the next time you cost me more the $100 to fix you are going to the scrap yard". You'd be amazed at how well this works. Before my 95 Pathy I had a '77 Old Delta 88 Royal. This technique got me an extra 2 years out of her. They can hear ya you know! Now I have to go as my alien communication device is almost finished! Jammer
  16. Oh crap!!!! I didn't need to hear that. Let me know what the damage was. Thanks
  17. Hey Red-Finder Did you hear from anyone with regards to your problem? This is exactly what mine is doing. I just had to get a rebuilt engine put in and now this!! I hope it is not a complete trany failure. Can anyone help us?!? Mine started with what sounded like the trany slipping (grinding sound) when shifting into reverse and it would suddenly catch. Now sometimes it goes into reverse AOK and other times it takes a few tried to get it in. The shift from 1 to 2 is also harder in that it goes into 2 with a bit of a thump.
  18. The wire runs down about five inches and joins another wire and they are wrapped but it looks like it may run around the passanger side and then it joins another group of wires that are covered. It looks like there are a couple of other plugs in the area that look the same. I'm so not a mechanic so it's hard to tell what is what. And how would I tell if I had a cooler on the trany? Jammer
  19. Thanks for the support Bernard. I have already got about $300 in parts at N/C and six hours of labour as well since they decided on their own to fix some stuff they found without checking with me first. And I'm not going to give up. They were more then happy to say they could do the job but suddenly now that there are problems they say it's not their fault and if I wanted it perfect I should have bought a "new" engine. I know the owner and I haven't had to go to him yet. I'm keeping that in my back pocket for the last time I go in there. Has anyone else put a 92 or 93 motor in a 95 and had problems with wiring harnesses matching up? Another question for everyone... would it be possible for them to damage or hook up the auto transmission wrong when they replaced the engine? I wasn't experiencing problem till about a week after I got the engine done. There is a delay sometimes when I put it into reverse and it feels like a slightly harder shift going into second gear. I asked they guys at Nissan and they said it was most likly the seals that would have to be redone and they quoted me $2200 CND to do it. I do have 205 000 km on the tranny and I do plow with it as well. Fluid is OK. Any thoughts? Jammer
  20. And here is the harness with the wiring problem.
  21. Lets try this attachment thing again.
  22. Would not surprise me if he was an idiot. Here is a picture of the sensor. I have also included a picture of one of the wiring harnesses that Toyota "modified" trying to fix the problem. The new end on the new engine didn't match up so they said they called a Nissan dealer and this was something he suggested. I'm not sure what wires they pulled out but I know they are putting them back. Is it an O2 sensor?
  23. I got a used engine (92 or 93) put into my 95 Pathfinder and the check engine light came on about 5 min after I left Toyota (closest Nissan is 2.5 hrs away). I took it back, they cleared the codes and the light went off but came on again 5 min later and was staying on all the time. Just the other day it started going off and then coming on again every so often. No real pattern to it. I took it to a Nissan dealer finally and the same thing happened. They checked everything, as there is no code to read and couldn’t find any problem. The light was off when I picked it up and it came on again 5 min later. One thing they did find was an O2 sensor they forgot to connect. Apparently it is supposed to connect somewhere near the middle of the engine so it looks like Toyota is going to have to take some stuff off to reconnect it. That should piss them off cause I’m not paying for it! The mechanic at Nissan said the O2 sensor wouldn’t cause the check engine light to come on so I’m still trying to figure it out. I have asked this question before but at the time the light was staying on. So now that it goes on and off I thought I’d ask again.
  24. Pathfinders rock but come on lets see some wishing here!! Early 90's 300 ZX twin turbo in mint shape. Man that car flew!!! I just drove one of the new Mustangs with the 4.6 V8 the other day. That is one beeeeeeeeeeeautiful car. It makes up for the last 15 years of ugly Mustangs. I pulled out to pass a truck and suddenly I was doing 165 KPH and still pulling. My problem with most of the new 4x4s on the market is they are all round. I like the box styling of my 95 Pathfinder. :Magic:
  25. Oh thanks! Something else to keep me awake at night. That's one of the problems with owning a vehicle without a local garage that's knowledgable with it. No one else here will touch it except Can Tire and I swore I'd never go there again. On the up side putting in a different motor fixed a lot of problems. I like many others had broken bolts and now it's quiet when I start it up. I was also having power issues around the 80 KMH mark and that's cleared up. And I always had a weird sound from the engine comp. that never changed. It sounded like a belt problem or something in that area as it was constant. The sound was there sice day 1 in '96 and never changed and two Nissan places wern't able to diagnose it. And since it wasn't causing harm the answer was to always leave it alone. One other question for you...what RPM should I be at around the 100 kmh mark on a level road? I'm around 2800.
