ok so this is the process im going through
what i have srated with
a 93 pathfinder with origional vg30i
the vg30i (93 pathfinder)
stuffed bottom end including the block and pistons
i have all the top end but the heads are in bad shape
i have all the maf and other bits and pieces.
the vg30e. (88 Terrano)
stuffed bottom end but the crank is good and pistons stuffed
heads are good (but i want to run the I not the e)
the vg33 ( R50)
top end absolutly stuffed. i needed a shovel to get rid of the sludge
but saprisingly there is no sludge around the block or inside the oil pump
i have all 3 motors spread out accross the garage and are comparing parts to wich ones i can use and others i can discard
so far i have come up with the oil, water and heads are the same with only minor cahnges. and they are very minor.
but i do like where the oil filter is on the vg33
ill run the heads of the vg33I with the injection set up aswell.
the only issue i can come acroos is the piston boares are larger than the other vg33e and the vg33i and am not shure if this will affect the ecu
any other imput would be most appreciated
