CanadianPathyNut
Everything posted by CanadianPathyNut
GOT IT
i bought a trunk release solenoid, tore off the back panel on the inside of the door and attached the little metal string-wire to the hatch release on the inside of the door, I gorunded it and ran a 12g wire to the dash and installed the trunk release button, so i can open the rear window with a button, I then wired that button to my remote starter as an AUX so now I can open my rear window with the AUX button on my remote!!! GO ME!!
Did your wife leave you and take your R50?!
R50 Hidden Winch Mount recovery system
CanadianPathyNut replied to Runnerman's topic in 96-2004 R50 Pathfinders
IS IT JUST ME OR DOES IT LOOK LIKE THE FRONT BUMPER IS HALF OFF WHILE THE WINCH IS BEING USED?? RUNNERMAN? IS THIS HIDDEN MOUNT GOING TO AFFECT THE WAY MY BUMPER SITS ON MY TRUCK? CAUSE I DO NOT WANT TO HARM THE BUMPER -
did a full brake fluid flush today and could not find the LSV and now my pedal goes almost to the floor, can someone please tell me what the Load Sensing Valve looks like or tell me exactly where it is, because I could not find it and I am guessing that a 2002 LE 4x4 should have one, I need to bleed it!!! a picture would be great, thank you!
I have the Pioneer AVIC-D1 works wonders, its a great program and very easily programable, with a built in Yellow pages plus it can add waypoints without changing my final destination which i do love
the pathfinder BOSE system is a double DIN opening, when you install a "small" stereo which is a single DIN the kit that is used to make the "small" headunit fit comes with a cut out for storage under the headunit.
How many people would buy the 4 1/2" lift?
CanadianPathyNut replied to tmorgan4's topic in 96-2004 R50 Pathfinders
i would not think tiwce about it, i would for sure buy it, I would buy it right now if it was available -
if the repair kit is 2 metal strips that go down each side and some white goo that dries rick hard and 2 clamps that hold it all together then Yes, they used the kit. the day after they did it I raised the truck up on a lift and it looked as if they used a kit, thats when i figured this is a cmoon problem and it should have been a free fix
I ahde the same problem with my 02 jsut take it to a dealership its like $25 to fix,
275/70/R16's on AR767's with the AC 2" lift ME TOO
on monday I will be replacing my rootrs and pads, i heard something about needing to replace my inner bearing grease seal. where can I get a replacement one? and does anyone know where I can get really good step by step as how to d this, because this will be my first time replacing rotots and pads. i know that i need to repack the bearings so I wil be buying a good bearing grease but what else do I need??? please help me by the way I have a 2002 Pathfinder LE
anyone know where I can buy the lightbulbs for my dash? one burned out and it is the one that tells me my brites are on, i have been looking on thbe internet for 3 months now, i looked everywhere please help
i installed a trunk release solenoid and put the button up near the drivers seat then I hot wired it so I could open the rear window with the car on or off, wuite an easy install to be honest with you!
I have the rancho RS9000X with the adjustable knobs, but I really love the look of the shcoks with a resevoir. Are there any shocks available for a 2002 Pathfinder LE with the 2" AC lift? I have been searching for hours, and have found nothing, money is no object here, I jsut want a shock with a resevoir. thank you
Rear Suspension Bushings
CanadianPathyNut replied to CanadianPathyNut's topic in 96-2004 R50 Pathfinders
yeah I have no idea why they told me to replace the bushings and control arms, my truck handles fine, but they said they need replacing, and I never argue with dealerships. We have a truck lift at school, it has 2 ramps and is open in the middle and the ramps lift up so the truck is left on all 4 wheels, i use this lift to do oil changes. I love it. Im going to replace the entire lower control arm, do you know where I can get instructions as to how to do it. also what part do i want to order? is this all I need: LOWER control arm, Pathfinder, All, Auto Trans, 4WD, Right - COIL SPRING LOWER control arm, Pathfinder, All, Auto Trans, 4WD, Left - COIL SPRING BUSHINGS, Pathfinder, Rear, Auto Trans, 4WD, Part Time - COIL SPRING what else should I order? and how do I do this? -
I took my truck in to the dealership today and had the exhaust leak looked at, they fixed it for like $200, but they told me I need to replace the rear suspension bushings, but you can't just replace the bushing you need to replace the whole arm i think, thats what the service writer told me. I want to know if anyone here knows about this, and if so do think its possible for me to save the $1000 i was quoted and do it myself? I am enrolled in auto tech at school so I have free use of lifts and any tool you can think of. I jsut want to know if this is something I could do myself? what do you think??please let me know
TIRES AND WHEELS, ITS FRIGGIN TIME!
I Bought the tires today they will be mounted and balanced tommorow I will post pictures of you guys want me to, I hope im not gonna have to trim too much and I REALLY hope these tires do not touch my struts -
http://store.yahoo.com/cruiserconnection/arbnispatsah.html go to this link and then search for a batter price, I would rather an ARB than TJM any day of the week, TJM sucks, jsut kidding, but I think ARB is better and it fits without modification
I noticed a puttering sound a few weeks ago coming from under the truck, today I took it to school and my auto tech teacher said I definately had an exhaust leak, he said it is propable cracked somewhere near the cat. Is this covered under warranty, btw i have a 2002 pathfinder LE. or should I jsut go to a muffler shop and install all new pipes and new exhaust and ofcourse remove the resonator. I have been searching this forum for hours, and i did come accross something in regards to it being under warranty for at least 100k I am at about 95000KMs. so if anyone knows what I should do, please let me know. also let me know if you think I should jsut get all new stuff and let a muffler shop fix it thank you
imsosorryitwillneverhappenagainipromiseyouthatiwillalwaystypeinlowercaselettersfromnowononceagainimveryverysorry -
i never could and still dont understand what the harm in caps is? its not like my message really actually hurts your eyes, these are letters I can not understand what the difference between this and THIS is?? -
OK SO ITS DONE AND DONE, I ORDERED 5 Bridgestone Dueller Revo AT's. THEY WILL BE HERE WEDNESDAY. I REALLY APPRECIATE EVERYONE'S INPUT AND IDEAS. IM SORRY TO HAVE HAD TO BOTHER YOU ALL. BUT ITS DONE NOW, NEW TIRES NEW WHEELS, ITS GONNA BE A GOOD WEEK, I CANT WAIT TILL NEXT WEEKEND NOW IM GONNA TEAR @!*% UP OVER IN THE MOJAVE DESERT. WELL ILL BE LURKING SO KEEP IT CLEAN YA'LL, PEACE! -
not anymore, she hurt my feelings -
no need to be afraid, its your truck I like not you how do I know what size to look for? what size will fit the 16” American Racing AR 767’s??? please help me in regards to what size to look for
