winch
glenn
Ideally you should have a winch with a capacity at least two times the weight of your vehicle. My Pathy weighs around 4300-4400 lbs loaded if I remember right.
Most of the time though, an 8000 lb winch will get you out of any stuck you're in.
Yeah, the generally repeated rule of thumb is double the vehicle weight as the one-size-fits-all recommendation.
But if you want to think a little for yourself, think about what you will need it for. The biggest factor by far is mud. When you get stuck in mud, you need to pull the truck, all the mud stuck to the truck, AND overcome all the resistance caused by the body parts stuck in the mud. So then you want at LEAST 2x of the vehicle weight, 3X is even better for southeast US gumbo mud.
But in dry sand, you won't need near as much. 1.5X of the vehicle weight will take care of 99% of what you encounter.
Edited by mws
Mine should be arriving today. :P
The first thing I'll be doing is ripping the package open to see where it was made... I'm so hoping it is still the original T-Max... :bow:
