glenn Posted May 21, 2006 Share Posted May 21, 2006 Hello all. What size/capacity winch to you all suggest?Thanks --glenn Link to comment Share on other sites More sharing options...
94extreme Posted May 21, 2006 Share Posted May 21, 2006 the higher the better. 8k lbs at the very minimum. 9k or 9.5k you're doing better. Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 22, 2006 Share Posted May 22, 2006 Ideally you should have a winch with a capacity at least two times the weight of your vehicle. My Pathy weighs around 4300-4400 lbs loaded if I remember right. Most of the time though, an 8000 lb winch will get you out of any stuck you're in. Link to comment Share on other sites More sharing options...
mws Posted May 22, 2006 Share Posted May 22, 2006 (edited) Yeah, the generally repeated rule of thumb is double the vehicle weight as the one-size-fits-all recommendation. But if you want to think a little for yourself, think about what you will need it for. The biggest factor by far is mud. When you get stuck in mud, you need to pull the truck, all the mud stuck to the truck, AND overcome all the resistance caused by the body parts stuck in the mud. So then you want at LEAST 2x of the vehicle weight, 3X is even better for southeast US gumbo mud. But in dry sand, you won't need near as much. 1.5X of the vehicle weight will take care of 99% of what you encounter. Edited May 22, 2006 by mws Link to comment Share on other sites More sharing options...
vengeful Posted May 22, 2006 Share Posted May 22, 2006 When I get a winch - probably sometime in July, it'll be a 10,000lb T-Max (probably get the Summit version for the virtue of cheaper cost and free shipping. ) Link to comment Share on other sites More sharing options...
mws Posted May 22, 2006 Share Posted May 22, 2006 Mine should be arriving today. The first thing I'll be doing is ripping the package open to see where it was made... I'm so hoping it is still the original T-Max... :bow: Link to comment Share on other sites More sharing options...
vengeful Posted May 22, 2006 Share Posted May 22, 2006 Definitely let me know, as I'm very strongly considering it! Link to comment Share on other sites More sharing options...
4wheeler Posted May 26, 2006 Share Posted May 26, 2006 Ive got a 6k ramsey and to test it i buried my truck facing up a sand dune, parked my buddies on top and dead weight pulled it up the dune. If i need more ill just put a snatch block and have a 9k winch. Link to comment Share on other sites More sharing options...
Filthy Luker Posted May 26, 2006 Share Posted May 26, 2006 9K winch checking in here. Bare minimum for what we do here. We already snap winch lines and destroy the motors. Link to comment Share on other sites More sharing options...
